itriix Posted November 3, 2009 Share Posted November 3, 2009 (edited) i'm just trying to figure out how to get "versioning" on my hdas... i read this in the help: The otversion HScript command and the equivalent python methods hou.NodeType.version and hou.NodeType.setVersion let you get and set the version number of a digital asset. The “version number” can actually be any text string. You can use a simple incrementing integer like “016” or more point number strings like “1.0.23”.You must unlock and save changes to the asset to save the version number change. You may want to maintain a version history in the documentation for the asset, listing the changes made to the asset in each version. i'm not sure where and how to go about doing this. And is this the common approach to getting versioning? I searched versioning and digital assets in the help file but couldn't find anything else. I swear I saw more about it somewhere one time i was looking through the help files though. Thanks, Jonathan Edited November 3, 2009 by itriix Quote Link to comment Share on other sites More sharing options...
SpencerL Posted November 3, 2009 Share Posted November 3, 2009 in the Operator Type Manager go to the hda that you want to version up. Right click > Save Copy... You can create a new version of the same hda this way Quote Link to comment Share on other sites More sharing options...
itriix Posted November 3, 2009 Author Share Posted November 3, 2009 (edited) in the Operator Type Manager go to the hda that you want to version up. Right click > Save Copy... You can create a new version of the same hda this way Thanks! When I right click the hda in the operator type manager, i only see: "copy" not Save Copy... is this what you're referring to? And i'm fairly new to "versioning", so assuming, this "copy" command is the correct one to be using, it says: in my example: Copy Sop/rampSOP operator from /Users/Jonathan/houdini10.0/otls/rampSOP.otl Operator Name: rampSOP Operator Label: RampSOP Save to Library: $HOME/houdini10.0/otls/OPcustom.otl... I don't want to mess anything up, so before I randomly try something, i thought i'd check with you first. To VERSION it, at this point in time, would i just change the: OPERATOR NAME to something like: rampSOP.v1 and leave the operator Label the same as before: RampSOP and would i save it into the rampSOP.otl that I originally saved. Or would I create a NEW .otl? something like, rampSOP.v2.otl? I'm assuming rampSOP.v2.otl because this would OVERWRITE the original im assuming? Thanks, Jonathan *EDIT* i just tried it, i left the operator name and label the same, and just changed the name of the .otl that i was saving it to to rampSOP_v2.otl and that seems to be exactly what i needed. Thanks!!!!! Edited November 3, 2009 by itriix Quote Link to comment Share on other sites More sharing options...
SpencerL Posted November 3, 2009 Share Posted November 3, 2009 Thanks! When I right click the hda in the operator type manager, i only see: "copy" not Save Copy... is this what you're referring to? And i'm fairly new to "versioning", so assuming, this "copy" command is the correct one to be using, it says: in my example: Copy Sop/rampSOP operator from /Users/Jonathan/houdini10.0/otls/rampSOP.otl Operator Name: rampSOP Operator Label: RampSOP Save to Library: $HOME/houdini10.0/otls/OPcustom.otl... I don't want to mess anything up, so before I randomly try something, i thought i'd check with you first. To VERSION it, at this point in time, would i just change the: OPERATOR NAME to something like: rampSOP.v1 and leave the operator Label the same as before: RampSOP and would i save it into the rampSOP.otl that I originally saved. Or would I create a NEW .otl? something like, rampSOP.v2.otl? I'm assuming rampSOP.v2.otl because this would OVERWRITE the original im assuming? Thanks, Jonathan *EDIT* i just tried it, i left the operator name and label the same, and just changed the name of the .otl that i was saving it to to rampSOP_v2.otl and that seems to be exactly what i needed. Thanks!!!!! Best to change it all. Typically we do Name: myHda_v001 Label: myHda_v001 Save to Library: $HOME/houdini10.0/otls/myHda_v001.otl The most important one to change is "Save to Library". If you keep that the same as your existing otl, then you will just be overwritting it with the copy. Best to change the label/name so that you know which otl you are sourcing. Hope this helps Quote Link to comment Share on other sites More sharing options...
itriix Posted November 3, 2009 Author Share Posted November 3, 2009 Yep, helps a lot! Thanks! Jonathan Quote Link to comment Share on other sites More sharing options...
edward Posted November 4, 2009 Share Posted November 4, 2009 The otversion and related functions are intended for integration with third party asset management systems. Quote Link to comment Share on other sites More sharing options...
