Somerville Posted June 12, 2003 Share Posted June 12, 2003 Could someone help me, I'm desperate. I have a sub d model that looks fine in the viewport until I view mantra. I see strange geometry flying out to unknown areas. I have turned on 'points' and there appear to be no stray points. Is this a rendering but with sub d models? It sounds like the model itself, but I do not know where to begin. Thank you, Chris S (SARS free Toronto, 0 days.) Quote Link to comment Share on other sites More sharing options...
Marc Posted June 12, 2003 Share Posted June 12, 2003 Do you have any displacements or shaders applied to it? Quote Link to comment Share on other sites More sharing options...
Somerville Posted June 13, 2003 Author Share Posted June 13, 2003 no displacements or shaders... Quote Link to comment Share on other sites More sharing options...
Somerville Posted June 13, 2003 Author Share Posted June 13, 2003 It looks like there is a render bug or some kind of bug with poly cap in sub d modeling. cs Quote Link to comment Share on other sites More sharing options...
Xiangbuilder Posted June 13, 2003 Share Posted June 13, 2003 Post your .hip or hipnc file here? Quote Link to comment Share on other sites More sharing options...
Jason Posted June 14, 2003 Share Posted June 14, 2003 Marc taught me this once: Turn on your primitive number display and check for zero-area polys on your geometry. If you see two primitive numbers on top of each other, follow up with a Blast SOP and type the number of the bad primitive in there. Sometimes a Facet SOP with "Remove Degenerate" turned on can help too - or the Clean SOP. The SubD algo kind of freaks out with zero-area polys and its pretty easy to get em if you've clipped your geometry in order to redo the symmetry (say, clipping a head in half to mirror it) Hope this helps, J Quote Link to comment Share on other sites More sharing options...
