Two sticky mud balls - Personal project
Emanuele Berti
Hi everyone,
I'd like to share with you my last personal project, "Two sticky mud balls".
I did everything in Houdini, hope you like it.
It's a final version but because it's more a technical experiment than a real work,
I didn't know if I had to post here or in the gallery.
HD (1280x720): www.vimeo.com/8717800
Full HD (1920x1080), Low-res (752x423), Case study and Making of:
http://www.leleberti.com/res.asp?job=9
Cheers,
Emanuele.
Edited by Emanuele Berti
Thanks Jason,
No SPH in this project, I started testing it but it was too heavy for my 32 bit laptop (memory limit), so I quit quite soon.
Yes, as you said I did displacement on geometry generated by particles fluid surface but just for the final shader,
before that I deformed the particles, through a VOP SOP, to simulate their accumulation based on their velocity and position.
To do that I baked an animated texture to create a sort of displacement map from particles.
Then I modify the position of those particles reading back the value from that texture,
and only after that I created the geometry from Particle fluid surface SOP...
Does it make sense? I hope it does :)
If you are interested, please take a look at the case study or the making of to see the entire process.
Cheers,
Emanuele
  • 1 month later...
