ranxerox Posted February 22, 2010 Share Posted February 22, 2010 hey all, I've been working on a generic setup for creating mist in scene using the pyro tools. I pretty much have what I want, all except for one thing: I'm getting this crazy flicker in the sim. Please takea look at the attached quicktime and hip file and see what I'm talking about. any ideas ? thanks -ranxx mist_v23.mov mist24.hip Quote Link to comment Share on other sites More sharing options...
Jason Posted February 22, 2010 Share Posted February 22, 2010 I don't know why you're getting that flicker (I haven't looked at the .hip) but perhaps you can defeat it by putting Substeps to 2 in the DOPnetwork parameters? These oscillation thing happens a lot in POPs (to me) and it's instantly solved by oversampling the simulation. If I get time, I'll look at your sim later. Good luck, Jason hey all, I've been working on a generic setup for creating mist in scene using the pyro tools. I pretty much have what I want, all except for one thing: I'm getting this crazy flicker in the sim. Please takea look at the attached quicktime and hip file and see what I'm talking about. any ideas ? thanks -ranxx Quote Link to comment Share on other sites More sharing options...
ranxerox Posted February 22, 2010 Author Share Posted February 22, 2010 hi Jason, thanks for your reply. I thought about that, and I put max substeps to 5 on the pyrosolver, but I didn't change the sub steps parameter on the AutoDopNetwork (I'm not sure how that works, does one control the other ? Are they independent ?). Anyway I'm going to resim it with sub steps to 2 on the autodopnetwork simulation tab and max sub steps at 5 on the pyrosolver and see how it goes. thanks -ranxx I don't know why you're getting that flicker (I haven't looked at the .hip) but perhaps you can defeat it by putting Substeps to 2 in the DOPnetwork parameters? These oscillation thing happens a lot in POPs (to me) and it's instantly solved by oversampling the simulation. If I get time, I'll look at your sim later. Good luck, Jason Quote Link to comment Share on other sites More sharing options...
ranxerox Posted February 23, 2010 Author Share Posted February 23, 2010 ok, to follow up on this, changing the max substeps to 2 in the simulation tab of the AutoDopNetwork node did the trick. I'm still not entirely clear as to why changing the substeps on the pyrosolver did not. I guess I'll have to dig into the docs and see what the difference is. thanks again. -ranxx hi Jason, thanks for your reply. I thought about that, and I put max substeps to 5 on the pyrosolver, but I didn't change the sub steps parameter on the AutoDopNetwork (I'm not sure how that works, does one control the other ? Are they independent ?). Anyway I'm going to resim it with sub steps to 2 on the autodopnetwork simulation tab and max sub steps at 5 on the pyrosolver and see how it goes. thanks -ranxx Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted February 23, 2010 Share Posted February 23, 2010 I was going to say try higher substeps. Glad you got it figured out. Quote Link to comment Share on other sites More sharing options...
