frading Posted June 25, 2003 Share Posted June 25, 2003 HI, I am trying to understand how to bypass/unbypass a list of operators, so that I can eaily switch from a slow version of my scene to a fast one. I would like to easily add operators to this list. I was thinking of making groups of them, as there is a button allowing to manage this for all operators in it, but..I would like this to be done automaticly by script, like before a render. And, althought you can change the flag states for any operators with "opset", I found no equivalent for groups. Why is this so? does anyone has a solution for this? At first, I was updating a script containing one by one all operators I wanted to bypass. but updating this script is not really handy. I was also thinking about putting a specific prefix for those operators, so that the cript could easily find them, but I don't really like that. so, any help or advice will be apreciated! Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted June 25, 2003 Share Posted June 25, 2003 I know some people like to use switch operators in conjunction with environment variables. set HIRES = 1 Then in your switch OPs have the switch parameter $HIRES. So when your doing tests or animating your have set HIRES = 0, when your render set HIRES = 1 jim. Quote Link to comment Share on other sites More sharing options...
frading Posted June 25, 2003 Author Share Posted June 25, 2003 yes, I am doing this too. this is really useful, but it means you have to put a switch for all OPs you want to bypass or not. this can make the graph quite heavy. But maybe it is me who is not really organised . So I was looking for another solution. And I am so much surprised not to find an equivalent of "opset" for groups... Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted June 25, 2003 Share Posted June 25, 2003 And, althought you can change the flag states for any operators with "opset", I found no equivalent for groups. Why is this so?does anyone has a solution for this? Loop through each OP in a group and turn on the bypass flag. foreach obj (`execute("opgls -L")`) opset -b on $obj end jim. Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted June 25, 2003 Share Posted June 25, 2003 You can use the above in conjunction with the Pre-Render Script. Which you can specify in the Scripts Tab in the Mantra Output Driver. You end the location of your turn_on_hires_objects.cmd and right before the render it will run the script. It works, I just tried it. jim. Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted June 25, 2003 Share Posted June 25, 2003 Duh, I forgot, instead of using the foreach script above you could just use pattern matching. opset -b on @myGroupName I need caffeine. jim. Quote Link to comment Share on other sites More sharing options...
Marc Posted June 26, 2003 Share Posted June 26, 2003 I need caffeine. One steamin' hot cuppa joe coming right up.... Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted June 26, 2003 Share Posted June 26, 2003 LOL, thanks Marc. The cup of joe will help wash down one of the many tasty assortments from Think Geek's Caffeine Line By the way, the Case of Bawls is a proud recipient of the acclaimed "Wolfwood's Turbo Zombie Seal of Approval". jim. Quote Link to comment Share on other sites More sharing options...
