Irradiance cache and occlusion VEX
Hello, guys.
How I can use irradiance cache on the full irradiance GI light, but dont use it at vex occlusion in shaders?
when i'am enabling irradiance cache in global mantra settings - its affect at all AO nodes too :(
thanks
You can add the vm_gienable parameter (from the gear menu) to objects you don't want included in the global irradiance cache.
I don't think there's a way to set that per-shader though.
what about adding this to material Properties shader? that way it should be possible to control that on per-material basis, i have not tested it though
Didn't work for me. Maybe soho only picks up certain properties from the material. That shouldn't be too difficult to change then.
