one curve from multible curves
hi,
is there a simple way to fuse ore stitch 2 curves together to get one single object with propper pointorder... i have several elements like bezier's from illustrator and handdrawn houdinicurves...
later the curve should be animated with a carvenode what breaks the connection after merge>stitch>fuse ... ?!
THX
cpb...your example exactly describes the issue.... it can't be that hard?! especially in my case i d like to fuse two beziers which make the rebuilding with same tangents harder... resampling each curve before rebuild?
anyone? ...
thx
Edited by hatrick
