Timeline display during flipbook generation
When I generate a flipbook my timeline doesn't update so I don´t know which frame is it, if I let the channel editor opened I can see the timeline bar but it is just a way around it(sorry the bad English).
Anyone ever had this problem? Anyone knows how to fix it?
thanks
Edited by tomhanks
I know this behavior. Didn't think of it as a bug, but I would like to see the current frame in the timeline, too. So thanks for the workaround with the channel editor, will test that out.
Edited by LFX
Glad to know that it´s just not me, not too glad about the problem itself though.
About the Python solution, it seems a good one but i never did nothing with python on houdini can you give e hint about how to create a python object operator?
Hey tomhanks, I would'nt call that a "solution" but more a "cheap hack" really
> go to : File/New Operator Type
Operator Name : outputFrame
Operator Label : outputFrame
Operator Style : Python Type
Network Type : Object Operator
Save To Library : your_otl_path/outputFrame.otl
Install Library To : Scanned OTL Directories
> click Accept
in the "code" tab, add: print hou.frame() ,after the 2 yellow lines of code.
> click Accept
in your network editor, you can now lay down a "outputFrame" node ( in Object Level )
that will display the frame number in a python pane
have fun with Python !
Edited by bunker
thanks
You can use the font sop, with $F as the text. Just place it off to the side and uncheck the center text options.
Another really simple solution:
- create a single point with an ADD sop ( place it on the corner of your frame )
- Create an attribute called "myframe" and set its valued to "$F"
- use the display options to display that attribute as a text.
Now that is very clever.
