petz Posted September 24, 2010 Share Posted September 24, 2010 i recently changed from python 2.5 to 2.6. while i´m used to use some modules a lot (especially numpy) i had never problems importing them in houdini, but today i got an error message when i try to import numpy in hython 2.6. importing numpy in regular python 2.6 works fine and also hython 2.5 has no trouble with the module (numpy for python 2.5 of course) but hython 2.6 seems to have problems with the dlls. i guess it´s related to the compiler used for the build but since numpy is the only module i have problems with, i´m not sure. does someone know how i can import the module without going back to python 2.5 in houdini? error message: importerror dll load failed 1 is not a valid win32 application thanks, petz Quote Link to comment Share on other sites More sharing options...
envil Posted April 22, 2011 Share Posted April 22, 2011 i recently changed from python 2.5 to 2.6. while i´m used to use some modules a lot (especially numpy) i had never problems importing them in houdini, but today i got an error message when i try to import numpy in hython 2.6. importing numpy in regular python 2.6 works fine and also hython 2.5 has no trouble with the module (numpy for python 2.5 of course) but hython 2.6 seems to have problems with the dlls. i guess it´s related to the compiler used for the build but since numpy is the only module i have problems with, i´m not sure. does someone know how i can import the module without going back to python 2.5 in houdini? error message: importerror dll load failed 1 is not a valid win32 application thanks, petz Hi! Do you solve this?! Quote Link to comment Share on other sites More sharing options...
Macha Posted April 26, 2011 Share Posted April 26, 2011 I used to have numpy installed with H10. But since H11 I can't anymore. I'd be nice to get it going again. Quote Link to comment Share on other sites More sharing options...
dulo Posted October 6, 2011 Share Posted October 6, 2011 Hi! Do you solve this?! It seems like your numpy installation was compiled with the wrong compiler. At the moment i am using houdini 11.1.33 x64 python 2.6 with numpy without problems, but i had to compile myself with vc2005 to make it work. The precompiled packages didnt work ( i think they are compiled with vc2008 for python2.6 and maybe the old ones for python 2.5 where compiled with vc2005 and thats why they worked. ) Quote Link to comment Share on other sites More sharing options...
