Macha Posted October 29, 2010 Author Share Posted October 29, 2010 Hm, yes we were thinking about Deadline as well. We have 3 nodes of it and wonder if we should switch to it for all our apps. If people have here have good experiences with it, we may go for it too. Quote Link to comment Share on other sites More sharing options...
Ostap Posted November 4, 2010 Share Posted November 4, 2010 Perhaps how HQueue directly specify where files IFDs? I'm always an error is to generate IFDs "Generate IFDs", in what could be the problem? Quote Link to comment Share on other sites More sharing options...
Macha Posted November 4, 2010 Author Share Posted November 4, 2010 I'm always an error is to generate IFDs "Generate IFDs", in what could be the problem? Here's what I worked out so far, maybe that helps: First you only need to assign one machine to generate ifds (if you have one master licence). But even then it messes up quite often. You need to restart the machine from HQueue but it never works so another way is to go into the HQclient folder and delete a file with .pid extension and then rerun the .bat file. For some reason it doesn't always get deleted. If that fails you can try deleting the whole folder and re-run the python script. I'm now at a point where all of this has failed and I have no more options. The support-men don't know what to do. Great fun! You'll easily waste days with! Good luck! Quote Link to comment Share on other sites More sharing options...
Ostap Posted November 4, 2010 Share Posted November 4, 2010 Here's what I worked out so far, maybe that helps: First you only need to assign one machine to generate ifds (if you have one master licence). But even then it messes up quite often. You need to restart the machine from HQueue but it never works so another way is to go into the HQclient folder and delete a file with .pid extension and then rerun the .bat file. For some reason it doesn't always get deleted. If that fails you can try deleting the whole folder and re-run the python script. I'm now at a point where all of this has failed and I have no more options. The support-men don't know what to do. Great fun! You'll easily waste days with! Good luck! Thanks for the reply, but problem in python, my previous version 2.6.6, then set 2.6 - everything worked! But still problem: All renderings incredibly slow. Quote Link to comment Share on other sites More sharing options...
Macha Posted November 5, 2010 Author Share Posted November 5, 2010 Well, it doesn't work for me. HQueue drives me nuts. Can anybody see from this here why my clients don' trender and instead eternally "waiting for machine"? JOBS | CLIENTS | GROUPS | HELP Name: Render -> HIP: PlaystationLines_Friday.hip IFD: $F.ifd (Frame: 2) Id: 467 Parent Job 464 Status: waiting for machine Overall Progress: 0% ETA: ∞ Properties: Less... Description: None Tries left: 0 Priority: 5 Min Hosts: 1 Max Hosts: 1 Tags: single Queue time: November 05, 2010 12:12:37 PM Runnable time: November 05, 2010 12:12:37 PM Command start time: Command end time: Start time: End time: Progress: Unknown Requirements: os == windows Environment: HQCOMMANDS {"hythonCommandsLinux": "export HOUDINI_PYTHON_VERSION=2.6 && export HFS=\"$HQROOT/houdini_distros/hfs.$HQCLIENTARCH\" && cd $HFS && source ./houdini_setup && hython -u", "pythonCommandsMacosx": "export HFS=\"$HQROOT/houdini_distros/hfs.$HQCLIENTARCH\" && $HFS/python/bin/python2.6-64", "pythonCommandsLinux": "export HFS=\"$HQROOT/houdini_distros/hfs.$HQCLIENTARCH\" && $HFS/python/bin/python2.6", "pythonCommandsWindows": "(set HFS=!HQROOT!\\houdini_distros\\hfs.!HQCLIENTARCH!) && !HFS!\\python26\\python2.6.exe", "mantraCommandsLinux": "export HFS=\"$HQROOT/houdini_distros/hfs.$HQCLIENTARCH\" && cd $HFS && source ./houdini_setup && $HFS/python/bin/python2.6 $HFS/houdini/scripts/hqueue/hq_mantra.py", "mantraCommandsMacosx": "export HFS=\"$HQROOT/houdini_distros/hfs.$HQCLIENTARCH\" && cd $HFS && source ./houdini_setup && $HFS/python/bin/python2.6-64 $HFS/houdini/scripts/hqueue/hq_mantra.py", "hythonCommandsMacosx": "export HOUDINI_PYTHON_VERSION=2.6 && export HFS=\"$HQROOT/houdini_distros/hfs.$HQCLIENTARCH\" && cd $HFS && source ./houdini_setup && hython -u", "hythonCommandsWindows": "(set HOUDINI_PYTHON_VERSION=2.6) && (set HFS=!HQROOT!\\houdini_distros\\hfs.!HQCLIENTARCH!) && (set PATH=!HQROOT!\\houdini_distros\\hfs.!HQCLIENTARCH!\\bin;!PATH!) && !HFS!\\bin\\hython -u", "mantraCommandsWindows": "(set HFS=!HQROOT!\\houdini_distros\\hfs.!HQCLIENTARCH!) && !HFS!\\python26\\python2.6.exe !HFS!\\houdini\\scripts\\hqueue\\hq_mantra.py"} HQPARMS {"frames": [2], "project_name": "marc_PlaystationLines_Friday", "image_paths": ["//192.168.1.13/x/Houduni/Playstationwaves/render/waves2.pic"], "ifds": ["//192.168.1.13/x/Houduni/Playstationwaves/ifds/2.ifd"], "delete_ifds": false} Linux Command: export HFS="$HQROOT/houdini_distros/hfs.$HQCLIENTARCH" && cd $HFS && source ./houdini_setup && $HFS/python/bin/python2.6 $HFS/houdini/scripts/hqueue/hq_mantra.py Windows Command: (set HFS=!HQROOT!\houdini_distros\hfs.!HQCLIENTARCH!) && !HFS!\python26\python2.6.exe !HFS!\houdini\scripts\hqueue\hq_mantra.py Macosx Command: export HFS="$HQROOT/houdini_distros/hfs.$HQCLIENTARCH" && cd $HFS && source ./houdini_setup && $HFS/python/bin/python2.6-64 $HFS/houdini/scripts/hqueue/hq_mantra.py Command Output: Download Output Quote Link to comment Share on other sites More sharing options...
Macha Posted November 5, 2010 Author Share Posted November 5, 2010 By the way, for days now it keeps coming up with occasional error messages containing the letters "rpc". I wonder if that has anything to do with it. Quote Link to comment Share on other sites More sharing options...
kubabuk Posted November 5, 2010 Share Posted November 5, 2010 (edited) For the rpc part check the following link: http://www.sidefx.com/docs/houdini11.0/hom/rpc If I'm not wrong HQ is built on top of that module. Which build of HQ are you using? Perhaps it will be better to upgrade to the most recent houdini build.... Sorry, I know it doesn't answer your question. Did you sent messages to the support? I would ask directly the hq developer, since this might be a network issue. It's hard to say anything at the moment. Edited November 5, 2010 by kubabuk Quote Link to comment Share on other sites More sharing options...
kumpa Posted March 22, 2011 Share Posted March 22, 2011 Hey everyone ! I just set up hqueue on one machine that at the moment acts as both server and client. I managed to add another client but says following: No licenses could be found to run this aplication Please check for a valid license server host. My question is: Where do i tell clients where to take licenses form ? Thanks a lot k Quote Link to comment Share on other sites More sharing options...
kumpa Posted March 22, 2011 Share Posted March 22, 2011 Nvermind, solved I forgot there is hkey for each version of houdini on hqueue... Works like a charm Quote Link to comment Share on other sites More sharing options...
kumpa Posted March 24, 2011 Share Posted March 24, 2011 I have another problem: hqueue is running perfectly, doesn't crash, renders every frame, but: each client takes only one license which results in 6 core machine with ht using one thread. Not ideal. To me it looks like there is cap on how many licenses clients are allowed to take. I am running freshly installed computers with ubuntu 10.10 and I have one master license and 50 mantras. Anyone ever experienced similar issues ? cheers k Quote Link to comment Share on other sites More sharing options...
Byter3 Posted May 18, 2017 Share Posted May 18, 2017 Hello guys! I can't setup Hqueue for some reason, I tried evrything you just said above, and I also watched the masterclass about distributed simulations in H15. I could add all of my clients to HQueue and the web interface works too, I even can submint simulations to the farm. But when a clinet pick up the job, almost immeadietly failed the job, and the only thing I got in the output log is: “Could not find output file for job ‘18’.” The other very strange thing is I sliced my simulation into 2 slices, but HQueue only wants to dedicate one machine to the job. I'm using Deadline for rendering, but now I need distributed simulations. Please help me if you can! Thanks! Cheers! Quote Link to comment Share on other sites More sharing options...
