feedback loop in COPS
pgrochola
  • 3 years later...
  On 6/16/2014 at 9:54 AM, nicknew said:
Hey Pav, how's it going?!
Did you ever get an aswer to this? I'm trying to find out myself but that link doesn't seem to work any more.
Nick.
That is probably because sidefx.com seems to be down atm.
edit: Seems to be up again.
Edited by Skybar
i heard that some kind of scripting will get you through the hoops of loading an image from disk
and recursively applying your COPS filter to it...
you can see some reuslts from a working HDA i used on this youtube link
https://www.youtube.com/watch?v=H1MH9uLcGJI
unfortunately i dont recall exactly how it was made
  • 3 years later...
Hi everyone,
I am trying to use a VOP COP Filter inside of a Loop COP. But even the simplest stuff doesn't work. Sometimes it does only one iteraition, sometimes the output is just black.
Am I doing something wrong, or is it unsupported or broken?
loop_cop.hipncFetching info...
Edited by AlSk
  • 2 weeks later...
same here, it seems loop cop doesn't like vop filter nodes. If you use a color correct node for example it works.
Also, I was trying to access the iteration number with the local var $AI but it seems it always returns zero.
