DeehrBYU Posted December 3, 2010 Share Posted December 3, 2010 I have a boy's head that I am masking out and just rendering the hair on top of it with shadows casting onto the face caused by the hair. The problem I run into is that the shadowmatte will also cast shadows onto itself. Does anyone know how I can stop this? Quote Link to comment Share on other sites More sharing options...
mangi Posted December 3, 2010 Share Posted December 3, 2010 I have a boy's head that I am masking out and just rendering the hair on top of it with shadows casting onto the face caused by the hair. The problem I run into is that the shadowmatte will also cast shadows onto itself. Does anyone know how I can stop this? Hi there joel. Not to sure what your after, but what I got out of this bomb question is here in the snap shot, Actual I was just looking into the render parameters for geomtry in housini, under the rendering Parameters. Here is the snap shot , You may have even done this and I over looked the question. Just for the hell of it. cheers mangi Quote Link to comment Share on other sites More sharing options...
mangi Posted December 3, 2010 Share Posted December 3, 2010 Hi there joel. Not to sure what your after, but what I got out of this bomb question is here in the snap shot, Actual I was just looking into the render parameters for geomtry in housini, under the rendering Parameters. Here is the snap shot , You may have even done this and I over looked the question. Just for the hell of it. cheers mangi And one last thing to get the shadow on the face, You have to get the face object out of the shadow mask in the light linker Snap shot agian should work fine . mangi Quote Link to comment Share on other sites More sharing options...
mangi Posted December 3, 2010 Share Posted December 3, 2010 And one last thing to get the shadow on the face, You have to get the face object out of the shadow mask in the light linker Snap shot agian should work fine . mangi & The Compo. Well just for the hell of it , I was curious to see the result . Of this kind of cool and crazy question. Here is the compo good by mangi Quote Link to comment Share on other sites More sharing options...
DeehrBYU Posted December 4, 2010 Author Share Posted December 4, 2010 brilliant! thats what I needed to do, was break he link between the face and the light. Thanks so much. Sorry my question was poorly worded to begin with. Quote Link to comment Share on other sites More sharing options...
moondeer Posted May 13, 2012 Share Posted May 13, 2012 (edited) one last question on this thread. can linker pane choices be included in takes? i've only been able to add the display toggle to the take list from the linker pane. i am surprised that light linking is not 'take-able', so now i doubt conclusions and hope i am wrong. i've just noticed that using the linker pane in shadow mode just adds objects to the 'shadow mask' field of the light itself. nice. so, rather than try to use the linker pane in a take, i should just add the shadow mask field in the light to the take. it would however be nice if an 'Include in take' was available directly on the linker pane lineitems. Edited May 13, 2012 by moondeer Quote Link to comment Share on other sites More sharing options...
mangi Posted May 14, 2012 Share Posted May 14, 2012 one last question on this thread. can linker pane choices be included in takes? i've only been able to add the display toggle to the take list from the linker pane. i am surprised that light linking is not 'take-able', so now i doubt conclusions and hope i am wrong. i've just noticed that using the linker pane in shadow mode just adds objects to the 'shadow mask' field of the light itself. nice. so, rather than try to use the linker pane in a take, i should just add the shadow mask field in the light to the take. it would however be nice if an 'Include in take' was available directly on the linker pane lineitems. Quote Link to comment Share on other sites More sharing options...
mangi Posted May 14, 2012 Share Posted May 14, 2012 Hi there. Are you just doing this then to get the linker into a take. Mangi Quote Link to comment Share on other sites More sharing options...
moondeer Posted July 4, 2012 Share Posted July 4, 2012 yes exactly that was the solution. i was looking for that ability within the lightlinker pane though. it is not there. as your pic shows, i had to go to the light directly to add the shadow mask field to the take. Quote Link to comment Share on other sites More sharing options...
