Omy Posted February 16, 2011 Share Posted February 16, 2011 Hi Can you tell me how to get the value of mass,speed from dops to sops.I have used the dopfield expression in a attribute create node.is that the way? could you discuss about this more.thank Quote Link to comment Share on other sites More sharing options...
Omy Posted February 20, 2011 Author Share Posted February 20, 2011 Hi Can you tell me how to get the value of mass,speed from dops to sops.I have used the dopfield expression in a attribute create node.is that the way? could you discuss about this more.thank could any body help me out? Quote Link to comment Share on other sites More sharing options...
anim Posted February 20, 2011 Share Posted February 20, 2011 help you with what? dopfield is the way, do you have any problems using it? you can also use Dynamics CHOP to extract data from DOPs Quote Link to comment Share on other sites More sharing options...
Omy Posted February 21, 2011 Author Share Posted February 21, 2011 help you with what? dopfield is the way, do you have any problems using it? you can also use Dynamics CHOP to extract data from DOPs for some reason it dint work for me,i tried with the attribcreate and a dopfield with the sim of a simple sphere falling the ground.could you share a file.many thanks Quote Link to comment Share on other sites More sharing options...
mawi Posted February 21, 2011 Share Posted February 21, 2011 for some reason it dint work for me,i tried with the attribcreate and a dopfield with the sim of a simple sphere falling the ground.could you share a file.many thanks Why dont you post your .hip so someone can have a look at what you are trying to do and correct what you are doing wrong? Quote Link to comment Share on other sites More sharing options...
Omy Posted February 21, 2011 Author Share Posted February 21, 2011 Why dont you post your .hip so someone can have a look at what you are trying to do and correct what you are doing wrong? this is the file.nothing fancy Quote Link to comment Share on other sites More sharing options...
Omy Posted February 21, 2011 Author Share Posted February 21, 2011 this is the file.nothing fancy dop_impactsattributes.hipnc Quote Link to comment Share on other sites More sharing options...
anim Posted February 21, 2011 Share Posted February 21, 2011 here is the example showing the usage of dopfield() the data which you can get by dopfield can be seen in Details View for DOP Network I don't know how you plan to use the data, so i just left it as detail attributes there is also CHOP network showing the alternative way of importing the data dop_impactsattributes_example.hipnc Quote Link to comment Share on other sites More sharing options...
Omy Posted February 21, 2011 Author Share Posted February 21, 2011 (edited) here is the example showing the usage of dopfield() the data which you can get by dopfield can be seen in Details View for DOP Network I don't know how you plan to use the data, so i just left it as detail attributes there is also CHOP network showing the alternative way of importing the data Hi many thanks.as a beginner i have some doubts? 0)dopfield("../../AutoDopNetwork","sphere_object1", "Impacts", "Impacts", 0, "positionx") dopfield("../../AutoDopNetwork","sphere_object1", "Position", "Options", 0, "mass") could you please explain me about the bold words in the above expression 1)do we need a chopnet to extract the info normally from DOPS? 2) and also why ? was used only for mass and not for velocity in one of the node Im beginning with Houdini and please apologize if my doubts sound stupid Thanks again! :-) Edited February 21, 2011 by Omy Quote Link to comment Share on other sites More sharing options...
Macha Posted February 21, 2011 Share Posted February 21, 2011 (edited) 0) If you look at the dops details view it will all become clear 1) no 2) ? is like * except that applies to characters, not multi-character strings. Velocity is a vector, mass a scalar. (Speed would be a scalar too) ps: anim, didn't know about HUD, great! Edited February 22, 2011 by Macha Quote Link to comment Share on other sites More sharing options...
Omy Posted February 22, 2011 Author Share Posted February 22, 2011 0) If you look at the dops details view it will all become clear 1) no 2) ? is like * except that applies to characters, not multi-character strings. Velocity is a vector, mass a scalar. (Speed would be a scalar too) ps: anim, didn't know about HUD, great! 0) i still dint understand the expression dopfield("../../AutoDopNetwork","sphere_object1", "Impacts", "Impacts", 0, "positionx")____________(1) dopfield("../../AutoDopNetwork","sphere_object1", "Position", "Options", 0, "mass")____________(2) In the above expression what are the Impacts,Impacts and Position and Options in (1) and (2) 1) could you tell me any other way to similar example many thanks Quote Link to comment Share on other sites More sharing options...
anim Posted February 22, 2011 Share Posted February 22, 2011 0) you need to look in Details View as I suggested to you to understand that just dive into your DOP Network and create new tab on any pane or split viewport pane and change that tab to Details View Here you can see all the data your of your DOP sim as a tree view expand it and under sphere_object1 branch you can see many data like ...Forces, Geometry, Position, Colliders, ... now scrub through timeline (if already simulated) with Details View open and you can see that on certain frames Impacts data appears in Details View under sphere_object1 if you expand this Impacts data, you can see it contains Basic and Impacts records, click on Impacts and you can see all impacts records data to fill in details view there may be more than 1 impact on certain frames so each impact has its index, position, normal, impulse and many other data which you can access with dopfield() according to dopfield() help http://www.sidefx.com/docs/houdini11.0/expressions/dopfield you need to fill in following dopfield(dop, objectSpec, subDataName, recordType, recordNum, fieldName) dop = your dopnet objectSpec = object in your dopnet (name or index) subDataName = data you can see in details view uder that object's branch (there are examples on that help page) recordType = again, further expand subData branch to find which recordTypes are availale for that data (Basic, Options, Impacts, ...) recordNum = in case of impacts for example this means index of impact, but if data contains only one record, this should be 0 fieldName = and finally the name of certain field in record, so in Impacts you can see "impulse" field so you write "impulse" here. But if you see that "position" field in Impacts records has the value like [-1,2, 1.23] that means it's vector, then you need to specify which component you want to extract, so you write "positionx" or "positiony"... in the fieldName so the same principle applies if you want to get mass look inside Details View mass field is under "sphere_object1" object, "Position" subData, "Options" recordType, 0 recordNum, "mass" field so the syntax will be dopfield("../../AutoDopNetwork","sphere_object1", "Position", "Options", 0, "mass") now CHOPs are alternative way of getting those info you need to use Dynamics CHOP and everything else should be clear from that example now that you know how to use Details View One last thing is Pattern Matching when you are specifying field names in Dynamics CHOP but they are used anywhere in Houdini http://www.sidefx.com/docs/houdini11.0/expressions/_patterns Quote Link to comment Share on other sites More sharing options...
Omy Posted February 22, 2011 Author Share Posted February 22, 2011 0) you need to look in Details View as I suggested to you to understand that just dive into your DOP Network and create new tab on any pane or split viewport pane and change that tab to Details View Here you can see all the data your of your DOP sim as a tree view expand it and under sphere_object1 branch you can see many data like ...Forces, Geometry, Position, Colliders, ... now scrub through timeline (if already simulated) with Details View open and you can see that on certain frames Impacts data appears in Details View under sphere_object1 if you expand this Impacts data, you can see it contains Basic and Impacts records, click on Impacts and you can see all impacts records data to fill in details view there may be more than 1 impact on certain frames so each impact has its index, position, normal, impulse and many other data which you can access with dopfield() according to dopfield() help http://www.sidefx.com/docs/houdini11.0/expressions/dopfield you need to fill in following dopfield(dop, objectSpec, subDataName, recordType, recordNum, fieldName) dop = your dopnet objectSpec = object in your dopnet (name or index) subDataName = data you can see in details view uder that object's branch (there are examples on that help page) recordType = again, further expand subData branch to find which recordTypes are availale for that data (Basic, Options, Impacts, ...) recordNum = in case of impacts for example this means index of impact, but if data contains only one record, this should be 0 fieldName = and finally the name of certain field in record, so in Impacts you can see "impulse" field so you write "impulse" here. But if you see that "position" field in Impacts records has the value like [-1,2, 1.23] that means it's vector, then you need to specify which component you want to extract, so you write "positionx" or "positiony"... in the fieldName so the same principle applies if you want to get mass look inside Details View mass field is under "sphere_object1" object, "Position" subData, "Options" recordType, 0 recordNum, "mass" field so the syntax will be dopfield("../../AutoDopNetwork","sphere_object1", "Position", "Options", 0, "mass") now CHOPs are alternative way of getting those info you need to use Dynamics CHOP and everything else should be clear from that example now that you know how to use Details View One last thing is Pattern Matching when you are specifying field names in Dynamics CHOP but they are used anywhere in Houdini http://www.sidefx.com/docs/houdini11.0/expressions/_patterns thanks a ton for your reply.I can understand things clearly after your reply.except sidefx links dint work.I guess its a help link Quote Link to comment Share on other sites More sharing options...
