PhasmaCeritus Posted March 1, 2011 Share Posted March 1, 2011 Hi, I have an issue with my $HIP variable being local. I am rendering on the render farm and I wish there was a way to tell houdini to set up $HIP as a network path. I have tried setting HIP manually in Edit -> Aliases and Variables but of course it's being overwritten with a local path after saving the scene file. So I was wondering 1. is there a way to set $HIP manually and force it not to update after saving the scene? 2. can I make Houdini to set up $HIP as a network path? I could create a new custom variable and assign my network path to it. but it would be a torture for me to go through my scene and update every single path that has $HIP in it. 3. is there a way to automatically change all the scene paths that contains $HIP? Maybe a python script that iterates through all the paths changing HIP in to something else..? Anyway, let me know if you have an idea how could I approach my problem Thanks Quote Link to comment Share on other sites More sharing options...
Marc Posted March 1, 2011 Share Posted March 1, 2011 I could be mistaken since I haven't used it in a while, but I have a feeling you should/would be better off using $JOB instead of $HIP. Quote Link to comment Share on other sites More sharing options...
PhasmaCeritus Posted March 1, 2011 Author Share Posted March 1, 2011 I could be mistaken since I haven't used it in a while, but I have a feeling you should/would be better off using $JOB instead of $HIP. Oh, that would have been great if I knew this from the beginning of my project, but now I have to go and change every $HIP to $JOB manually. I wish I would not have to do this... Is there a way around it? 1 Quote Link to comment Share on other sites More sharing options...
malexander Posted March 1, 2011 Share Posted March 1, 2011 Is there a way around it? Indeed there is: opchange -p / \$HIP \$JOB Save a copy first, just in case 1 Quote Link to comment Share on other sites More sharing options...
PhasmaCeritus Posted March 1, 2011 Author Share Posted March 1, 2011 Indeed there is: opchange -p / \$HIP \$JOB Save a copy first, just in case Amazing... Thanks a lot problem solved Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted March 2, 2011 Share Posted March 2, 2011 I think $HIP is the correct variable for rendering on a farm. That is what I use without any trouble. If I place my project file here. //machinename/folder/project.hip And I have a shared resource here //machinename/folder/textures/map.png then the path should be $HIP/textures/map.png Work's just fine on the render farm, as long as each node can access //machinename You can not do this with $HIP, at least the last time I tried it failed on the farm. $HIP/../someparentfolder/map.png p.s. That's on Windows, but the process is the same on Linux. 1 Quote Link to comment Share on other sites More sharing options...
Marc Posted March 2, 2011 Share Posted March 2, 2011 $HIP changes though depending on where you opened your file from. So it could work on your farm, but perhaps not somebody elses ... depends on how it's all setup. $JOB doesn't change unless you tell it to, so it's more reliable as a path. M 1 Quote Link to comment Share on other sites More sharing options...
PhasmaCeritus Posted March 3, 2011 Author Share Posted March 3, 2011 thanks guys $JOB and the little scripty script is what I needed so it's working now Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted March 3, 2011 Share Posted March 3, 2011 $HIP changes though depending on where you opened your file from. So it could work on your farm, but perhaps not somebody elses ... depends on how it's all setup. $JOB doesn't change unless you tell it to, so it's more reliable as a path. M ah.. ok. So my farm is setting the hip file's location as the current working folder, and on his farm it's opening it from a different folder. i get now. thanks. Quote Link to comment Share on other sites More sharing options...
