PhasmaCeritus Posted March 17, 2011 Share Posted March 17, 2011 correct me if I am wrong: once you hit render on mantra output node it creates a temporary IFD and then reads that IFD to render. is there a specific location where that temporary IFD is being saved? how do i change it? is there a way to render saved IFD from disk with a mantra node? Thanks! Quote Link to comment Share on other sites More sharing options...
bhaveshpandey Posted March 17, 2011 Share Posted March 17, 2011 Hi Tomas, you can define your own path if you check the disk file option. For rendering the ifd files have a look at these links: http://www.sidefx.com/docs/houdini9.5/rendering/commandline alternatively you can also render ifds by using the mantra -f command cheers 1 Quote Link to comment Share on other sites More sharing options...
PhasmaCeritus Posted March 17, 2011 Author Share Posted March 17, 2011 Hi Tomas, you can define your own path if you check the disk file option. For rendering the ifd files have a look at these links: http://www.sidefx.com/docs/houdini9.5/rendering/commandline alternatively you can also render ifds by using the mantra -f command cheers Thanks, I have read that info, but I would like to render IFD with a mantra node. I know that's a little redundant getting IFD from mantra rop and then using mantra rop to render that IFD. Also I would like to know what is happening under the hood once you hit "render" on mantra node when it set to render image (not IFD). Does it still generates temporarily IFD to render the image? If it does, where does it save that IFD by default? Thanks! Quote Link to comment Share on other sites More sharing options...
symek Posted March 17, 2011 Share Posted March 17, 2011 Thanks, I have read that info, but I would like to render IFD with a mantra node. I know that's a little redundant getting IFD from mantra rop and then using mantra rop to render that IFD. Also I would like to know what is happening under the hood once you hit "render" on mantra node when it set to render image (not IFD). Does it still generates temporarily IFD to render the image? If it does, where does it save that IFD by default? Thanks! I don't think Houdini saves IFD at all, more probably it sends it with stdout. As to general process, you can go through it step by step as it's all written with Python. For a reference see soho.py and IFD.py in $HH/soho/python2.x/ Houdini calls that IFD.py script when an user hits render button on Mantra ROP. Rendering ifd file with mantra node is trivial. Just execute "mantra -f myifd.ifd" in subprocess. 1 Quote Link to comment Share on other sites More sharing options...
edward Posted March 18, 2011 Share Posted March 18, 2011 I think Apprentice has IFD export disabled? Quote Link to comment Share on other sites More sharing options...
PhasmaCeritus Posted March 18, 2011 Author Share Posted March 18, 2011 thanks. Quote Link to comment Share on other sites More sharing options...
bhaveshpandey Posted March 18, 2011 Share Posted March 18, 2011 hey SY afaik it does render out ifd's from the mantra rop itself.. I was able to render it out and render the frame frame using the mantra command at my workplace last year..i have not tried it with apprentice though.. thanks for the info on the python script that's a useful insight. Quote Link to comment Share on other sites More sharing options...
symek Posted March 19, 2011 Share Posted March 19, 2011 Sure it does! I do it every day. I've thought the question was about interactive rendering when you render directly from houdini. I think in this case houdini streams ifd directly to mantra via stdin/stdout. Quote Link to comment Share on other sites More sharing options...
