Get Geometry/Object from selected points?
Hi guys
Is there anyway to get a whole geometry/object from selected points/primitives?
I have tried “group” SOP , but it seemingly only can transfer points <-> primitives bidirectionally(Edit Tab)
Thanks in advance
  • 3 years later...
What do you mean? I see a Group parameter on the Blast SOP.
The easy way to create connected groups procedurally is to append an Assemble SOP. The harder way is to look at how the Connectivity and Partition SOPs are used inside it.
Yes, there is a "Group" parameter, but there was a "Group Mask" parameter too, it's been removed in Houdini 14 .
I'm using an assemble SOP of course, then I tried to use "Delete By Expression" in the Delete SOP, but I get an error..
eh?- that is a custom parameter - you can simply add it to blastSOP in H14 if you like it.
