Barakooda Posted May 21, 2011 Share Posted May 21, 2011 (edited) I have different kind of images and want to trace them, project them on plane, then texture them with the same image and keep the proportions as much as possible with out tweaking the UVtexture or Project nodes... I have lots of issues with it... any help and hints\tips will be gladly welcome ! B. trace_project_project.hipnc Edited May 21, 2011 by Barakooda Quote Link to comment Share on other sites More sharing options...
Emanuele Berti Posted May 22, 2011 Share Posted May 22, 2011 HI, you wrote that you have lots of issues but because we don't have the file you are trying to trace... we can't really help you... Could you be more specific or upload a new hip file with your "for_trace.png" in it? Cheers, Emanuele Quote Link to comment Share on other sites More sharing options...
Barakooda Posted May 22, 2011 Author Share Posted May 22, 2011 (edited) . Edited May 22, 2011 by Barakooda Quote Link to comment Share on other sites More sharing options...
Barakooda Posted May 22, 2011 Author Share Posted May 22, 2011 Hi Emanuele! thank you for the reply, http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=22256 the for_trace.png is basicly the alpha layer of the png file... thanks_Emanuele.zip Quote Link to comment Share on other sites More sharing options...
anim Posted May 22, 2011 Share Posted May 22, 2011 here is modified file with notes i don't know why you need that projection so I avoided it, but if it's important for what you are doing just describe it further trace_project_texture_fix.hipnc Quote Link to comment Share on other sites More sharing options...
Barakooda Posted May 22, 2011 Author Share Posted May 22, 2011 (edited) here is modified file with notes i don't know why you need that projection so I avoided it, but if it's important for what you are doing just describe it further I wanted to use something i saw in L-system tutorial, deforming the leaf by override its points with simple l-system skeleton, why projection? after trimming it doesn't add or delete the points,so that the reason i used project, its kind of experiment i wanted to do. i upload example file. in the left side, there is general structure of how i made the leaf. in the right side, the example i tried to learn from and implement on my project (the project it self i cant upload) i will continue with anim simple structure for now and will deform the leaf later . thank you Tomas and Emanuele ! and sorry for my ability to express my self :-) Barak. L-system_Nurbs03.hipnc Edited May 22, 2011 by Barakooda Quote Link to comment Share on other sites More sharing options...
