Nico D. Posted May 30, 2011 Share Posted May 30, 2011 Hi, I'm creating an otl where I have 2 nodes with 2 different ramp parameters. Those parameters needs to be referenced, copying and referencing one ramp parameter onto the other one is not working. Any ideas? thanks Quote Link to comment Share on other sites More sharing options...
edward Posted May 31, 2011 Share Posted May 31, 2011 For multiparm parameters, you need to use the opmultiparm hscript command to link them. The easiest way to see what the right command is to promote a ramp parameter in an HDA and then run opmultiparm on the node containing the ramp inside. 1 Quote Link to comment Share on other sites More sharing options...
katisss Posted February 16, 2013 Share Posted February 16, 2013 (edited) I am interested in doing this but unfamiliar with opmultiparm. Can you explain? thanks EDIT got it working Edited February 16, 2013 by katisss Quote Link to comment Share on other sites More sharing options...
edward Posted February 16, 2013 Share Posted February 16, 2013 http://www.sidefx.com/docs/houdini12.1/commands/opmultiparm Quote Link to comment Share on other sites More sharing options...
katisss Posted February 19, 2013 Share Posted February 19, 2013 got it to work thanks Quote Link to comment Share on other sites More sharing options...
pelos Posted December 28, 2017 Share Posted December 28, 2017 can you explain how you set it up? i am trying to link 2 ramps with it, but i got stuck =( this is what i did: opmultiparm /obj/outside_ramp/outside_ramp /obj/outside_ramp/inside_ramp/inside_ramp Quote Link to comment Share on other sites More sharing options...
