Barakooda Posted June 11, 2011 Share Posted June 11, 2011 any nice idea how to create surface from the imported Pf-track points? Quote Link to comment Share on other sites More sharing options...
zarti Posted June 11, 2011 Share Posted June 11, 2011 hi , post few "points" , criterion , final objective , references , etc .. that wd be a good start . Quote Link to comment Share on other sites More sharing options...
mawi Posted June 11, 2011 Share Posted June 11, 2011 any nice idea how to create surface from the imported Pf-track points? Not to say it´s undoable in Houdini, but I think you can do it in pf-track and export the geometry from there. Quote Link to comment Share on other sites More sharing options...
bunker Posted June 11, 2011 Share Posted June 11, 2011 I did that before with a triangulate 2D and a point Sop. - use a point sop to set all the values to zero on one axis ( eg: $TX 0 $TZ ) - add a triangulate 2D : gives you polygons - put the values back onto the axis. put another point sop and plug the original geo into the second input. - set to : $TX $TY2 $TZ that works for a fairly flat ground for example. any nice idea how to create surface from the imported Pf-track points? Quote Link to comment Share on other sites More sharing options...
Barakooda Posted June 12, 2011 Author Share Posted June 12, 2011 Thanks guys ! Quote Link to comment Share on other sites More sharing options...
