Barakooda Posted June 11, 2011 Share Posted June 11, 2011 any nice idea how to create surface from the imported Pf-track points? Quote Link to comment Share on other sites More sharing options...
zarti Posted June 11, 2011 Share Posted June 11, 2011 hi , post few "points" , criterion , final objective , references , etc .. that wd be a good start . Quote Link to comment Share on other sites More sharing options...
mawi Posted June 11, 2011 Share Posted June 11, 2011 On 6/11/2011 at 7:02 PM, Barakooda said: any nice idea how to create surface from the imported Pf-track points? Not to say it´s undoable in Houdini, but I think you can do it in pf-track and export the geometry from there. Quote Link to comment Share on other sites More sharing options...
bunker Posted June 11, 2011 Share Posted June 11, 2011 I did that before with a triangulate 2D and a point Sop. - use a point sop to set all the values to zero on one axis ( eg: $TX 0 $TZ ) - add a triangulate 2D : gives you polygons - put the values back onto the axis. put another point sop and plug the original geo into the second input. - set to : $TX $TY2 $TZ that works for a fairly flat ground for example. On 6/11/2011 at 7:02 PM, Barakooda said: any nice idea how to create surface from the imported Pf-track points? Quote Link to comment Share on other sites More sharing options...
Barakooda Posted June 12, 2011 Author Share Posted June 12, 2011 Thanks guys ! Quote Link to comment Share on other sites More sharing options...
