Dinkleberry Posted June 22, 2011 Share Posted June 22, 2011 Hi, I've got the docs describing the data format that Houdini uses for the pipe CHOPs, but it seems like it could be a bit of a PITA to make an app that will understand everything H spits out. Is there an existing implementation out there? Quote Link to comment Share on other sites More sharing options...
kursad Posted June 29, 2011 Share Posted June 29, 2011 Hi, I've got the docs describing the data format that Houdini uses for the pipe CHOPs, but it seems like it could be a bit of a PITA to make an app that will understand everything H spits out. Is there an existing implementation out there? I am wondering the same thing Quote Link to comment Share on other sites More sharing options...
Jason Posted June 29, 2011 Share Posted June 29, 2011 You could take a look at this: http://whoudini.blogspot.com/2010/02/ok-i-know-i-promised-you-something-else.html Quote Link to comment Share on other sites More sharing options...
Dinkleberry Posted June 29, 2011 Author Share Posted June 29, 2011 You could take a look at this: http://whoudini.blogspot.com/2010/02/ok-i-know-i-promised-you-something-else.html I'd already seen that, but writing a client to process received messages is quite a different task. Cheers though. Quote Link to comment Share on other sites More sharing options...
fdevillalobos Posted October 2, 2015 Share Posted October 2, 2015 Anyone found any solution or option to this?? I just need to stream out an object orientation to a unix node. Any clues? Quote Link to comment Share on other sites More sharing options...
edward Posted October 10, 2015 Share Posted October 10, 2015 What do you mean to a unix node? If you're sending data from one Houdini to another Houdini, then you can just use a Pipe In CHOP on session and a Pipe Out CHOP on the other. Quote Link to comment Share on other sites More sharing options...
