Hello world Posted August 29, 2011 Share Posted August 29, 2011 I want to produce a simple neon light effect.im new to CG. I have used geo light options. I have attached the file. please help me out. thank you very muchgeolightdoubt.hipnc Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted August 29, 2011 Share Posted August 29, 2011 What exactly do you want help with? Where are you having trouble or getting stuck? Quote Link to comment Share on other sites More sharing options...
Macha Posted August 29, 2011 Share Posted August 29, 2011 Hey Brian. Have a look at cops also. If you render out a constant color pass for your light emitting object then you can use comping tricks for this too (blurring and sticking over) Quote Link to comment Share on other sites More sharing options...
Hello world Posted August 29, 2011 Author Share Posted August 29, 2011 What exactly do you want help with? Where are you having trouble or getting stuck? hey, i tried setting up geo lights to produce neon lights.but when i see in render view,nothing is getting displayed. Quote Link to comment Share on other sites More sharing options...
hkspowers Posted August 29, 2011 Share Posted August 29, 2011 You just needed to turn on the "render light geometry" flag to get it to show up. I also put a grid there so you could see the light you had was emitting light you just didn't have anything for it to light so looked black. You will still have to do some post glow on this to look like neon but this should get you started. geolightdoubt.hipnc Quote Link to comment Share on other sites More sharing options...
zarti Posted August 29, 2011 Share Posted August 29, 2011 hi , Hello world im not sure if you are doing this just to exclusively test the GeoLights , but if not , then i wd suggest a more ' perverse ' method ; Ambient Occlusion in shading context . first time i tried this but here it is a quick setup and few tests . and the scene .. neon.hipnc im not sure if this is mathematically correct though , but should render faster and with less headaches . =) .cheers Quote Link to comment Share on other sites More sharing options...
hkspowers Posted August 29, 2011 Share Posted August 29, 2011 That looks pretty sharp Zarti! Thanks for sharing. Quote Link to comment Share on other sites More sharing options...
Hello world Posted August 29, 2011 Author Share Posted August 29, 2011 @Zarti Fantastic! thank you! @James Thank you! Quote Link to comment Share on other sites More sharing options...
