Editing a curve in Geometry Spreadsheet
I have this closed Nurbs curve created using CVs and which only roughly looks like a shape that I want to create. (I was planning on editing point coordinates in Geometry Spreadsheet)
Now.
when I try and edit coordinates in Spreadsheet, only the Points are being moved to a new positions, not the CVs. Can anyone tell me how I can make CVs follow the points?
Thanks!
Hey Stremik
I think you've just discovered an interesting bug. :)
Try doing this :
1. draw a nurbs curve
2. append an edit SOP (just select all the points and right click)
3. now change a value of one of the points in the spreadsheet
4. now select a point in the viewport(a different point from the one who's position you just edited)
5. move the handle and see what happens. :)
For those of you to lazy to do this, the amount that the handle translates is continuously added to the previously edited point. So if you drag the handle up and down those values are added and the point shoots off into the sunset.
So I'm suggesting you post this on the SESI forum (feel free to link to this topic if you prefer) and let them know.
Cheers
Marc
