Fredrik Posted October 5, 2011 Share Posted October 5, 2011 Hi All, we are doing some work where we use realflow to create super slow motion liquid renders. The problem is that there is not enough continuity in how the meshes are built to avoid getting flickering bright highlights when we render. It seems to be a problem with the mesher and we are running out of ideas of things to try in Realflow to get rid of the jitter. I have seen some threads on the web with suggestions but it didn't sound like they solved it. Has anyone here had and solved this problem before, using Houdini? cheers fred Quote Link to comment Share on other sites More sharing options...
Ezz Posted October 5, 2011 Share Posted October 5, 2011 Hi Fred. Have you tried to decrease the polygon-size in RF? along applying filter to the mesher. You´ll end up with a higher resolution in your mesh, but maybe its the trick to use. You can try an see how well Houdini does the meshing by importing your RF-particles and apply a Particle Fluid Surface-SOP. Then export them back. http://www.sidefx.com/docs/houdini11.0/nodes/sop/particlefluidsurface Erik Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted October 6, 2011 Share Posted October 6, 2011 Typically when the mesh is flicking from RealFlow it stems from the user trying to make the mesh too sharp from a simulation that doesn't have enough resolution. It can also come from the polygon size being too large, especially if using the default. Can you post an image sequence of the flickering problem? Or if you want post a link if you posted in a RealFlow specific forum and we can go from there. Quote Link to comment Share on other sites More sharing options...
Fredrik Posted October 6, 2011 Author Share Posted October 6, 2011 This sounds like it could be the case. I believe we are shaping the mesh a fair bit with various mesher params. (sorry I am not the Realflow operator) It sounds like we need to try reducing the poly size as several people have been suggesting that. I'll try to get time to post an example. Typically when the mesh is flicking from RealFlow it stems from the user trying to make the mesh too sharp from a simulation that doesn't have enough resolution. It can also come from the polygon size being too large, especially if using the default. Can you post an image sequence of the flickering problem? Or if you want post a link if you posted in a RealFlow specific forum and we can go from there. Quote Link to comment Share on other sites More sharing options...
Fredrik Posted October 6, 2011 Author Share Posted October 6, 2011 Btw, how do I transfer particles from RF to Houdini? Do I really need that plugin? Can I do it via Maya? cheers fred This sounds like it could be the case. I believe we are shaping the mesh a fair bit with various mesher params. (sorry I am not the Realflow operator) It sounds like we need to try reducing the poly size as several people have been suggesting that. I'll try to get time to post an example. Quote Link to comment Share on other sites More sharing options...
Ezz Posted October 6, 2011 Share Posted October 6, 2011 (edited) I think its the easiest way to do. You can download it together with a trial of RF Erik Edited October 6, 2011 by Ezz Quote Link to comment Share on other sites More sharing options...
