simple NURBS extrusion question
David Gary
Hi.
Sorry I'm facing a little newbie problem
( bcoz i rarely explore the nurbs sops and largely prefer the Polygon-Subdivision scheme)
I'd like to extrude a NurbsCurve Profile/X-section along a NurbsCurve path.
The Skin or Sweep Sops make copies of the NurbsCurve Profile ( at each Path CV) and then put a skin. So the result is not smooth ( linear junction between each copy).
It usually satisfies me because i don't need too much precision but here
i need a smooth result
I'm sure there's a simple way to achieve a smooth result but i cannot find it.
Any help appreciated. :)
( i feel abit ashamed not to know my sops all by heart).
append a skin to the sweep. Keep output geometry off for the sweep. I don't see why you're not getting a smooth result.
You could also increase the order of the backbone curve or even refine it before sweeping
sometimes the OGL viewport looks a bit jaggie but renders fine
