Supersaqib Posted December 14, 2011 Share Posted December 14, 2011 (edited) Hi, Can i kindly request a compile for Win 64 HOT 11.1.118. Many Thanks Saqib Edited December 14, 2011 by Saqib 1 Quote Link to comment Share on other sites More sharing options...
Ungoliant Posted December 15, 2011 Share Posted December 15, 2011 Hi, Can i kindly request a compile for Win 64 HOT 11.1.118. Many Thanks Saqib try this Quote Link to comment Share on other sites More sharing options...
Ungoliant Posted December 15, 2011 Share Posted December 15, 2011 try this hotbin_win64_11,1,118_1.0rc9.zip Quote Link to comment Share on other sites More sharing options...
Supersaqib Posted December 15, 2011 Author Share Posted December 15, 2011 Thanks Buddy!! Epic for the speedy response. Can always rely on the houdini community. Quote Link to comment Share on other sites More sharing options...
Netvudu Posted December 20, 2011 Share Posted December 20, 2011 I installed succesfully over my H11.1.18, but now my other Houdini installations (namely h12 Betas) are complaining...any hints on how to make this work JUST for H11 without affecting other Houdini versions? I used both the HOUDINI_PATH and PATH environment variables. Quote Link to comment Share on other sites More sharing options...
jimbojones Posted December 20, 2011 Share Posted December 20, 2011 It won't work for me....keeps saying that it is for a different version of Houdini... Jim Quote Link to comment Share on other sites More sharing options...
edward Posted December 21, 2011 Share Posted December 21, 2011 I installed succesfully over my H11.1.18, but now my other Houdini installations (namely h12 Betas) are complaining...any hints on how to make this work JUST for H11 without affecting other Houdini versions? I used both the HOUDINI_PATH and PATH environment variables. Either only modify HOUDINI_PATH for when you start a specific version of Houdini. OR, don't modify HOUDINI_PATH and specifically install your plugins into $HOME/houdini11.1/.... Quote Link to comment Share on other sites More sharing options...
Novel Posted December 21, 2011 Share Posted December 21, 2011 Thnx, man! You've really helped me! I've tried to compile by myself, but failed... and had to use only SOP without VEX... But now I'm back on a horse! Quote Link to comment Share on other sites More sharing options...
Netvudu Posted December 21, 2011 Share Posted December 21, 2011 Either only modify HOUDINI_PATH for when you start a specific version of Houdini. OR, don't modify HOUDINI_PATH and specifically install your plugins into $HOME/houdini11.1/.... Hi thanks. I´m not used to dealing with environment variables, so I´m not sure about this. Let´s say I opt for your second option and I specifically install my plugins into $HOME/houdini11.1/...., should I then erase the HOUDINI_PATH environment variable, or restore it to something else? Also, how do I only modify HOUDINI_PATH for when I start a specific version of Houdini? Forgive my OS noobness... Quote Link to comment Share on other sites More sharing options...
edward Posted December 22, 2011 Share Posted December 22, 2011 If you choose to install into the $HOME/houdini11.1 directory tree, then do NOT set HOUDINI_PATH environment variable at all. This will then allow Houdini to use its default value which includes $HOME/houdini11.1. If you choose to only modify HOUDINI_PATH for a specific version of Houdini, then you should create a (version-specific) wrapper script that sets HOUDINI_PATH and then invokes Houdini. To launch Houdini, use the wrapper script. Quote Link to comment Share on other sites More sharing options...
Netvudu Posted December 22, 2011 Share Posted December 22, 2011 ah, that makes sense. Thanks edward. Quote Link to comment Share on other sites More sharing options...
Netvudu Posted December 29, 2011 Share Posted December 29, 2011 (edited) Ok, so now I got a new set of problems trying to make this work. (HOT just starting for 11.1.118 and not other versions) It happens, either if I try to change the houdini.env file, or if I try creating a .bat file to change the variables with a set command at startup (which is what I understood from edwards´ hint on "creating a wrapper script"...right?). At least, in both ways I get the same problem so it must somehow be related. (edited)blah,blah... EDIT: Wait! now I realized I was missing a ";&" at the end of the first Environment Variable, but now I get a different error. Here´s the screen grab. Edited December 31, 2011 by Netvudu Quote Link to comment Share on other sites More sharing options...
edward Posted January 3, 2012 Share Posted January 3, 2012 You cannot use houdini.env to modify HOUDINI_PATH because HOUDINI_PATH itself is used to find where houdini.env exists. You should post the contents of your .bat file. Offhand, I'm guessing that your wrapper script is still wrong. Quote Link to comment Share on other sites More sharing options...
Netvudu Posted January 3, 2012 Share Posted January 3, 2012 (edited) Oh, If there´s something I´m sure of, that is that my bat file is wrong I just don´t know why. Also thanks for the explanation on why I cannot adjust the env file directly... Bear with me.... @echo off set HOUDINI_PATH=C:\Program Files\Side Effects Software\hotbin_win64_H11.1.118_1.0rc9;& set PATH=C:\Program Files\Side Effects Software\hotbin_win64_H11.1.118_1.0rc9\dlls start "" "C:\Program Files\Side Effects Software\Houdini 11.1.118\bin\hmaster.exe" AS you can see I unzipped the HOT binary at "C:\Program Files\Side Effects Software\hotbin_win64_H11.1.118_1.0rc9" I thought it would be a good idea not to loose it around the Hard drive. Edited January 3, 2012 by Netvudu Quote Link to comment Share on other sites More sharing options...
edward Posted January 3, 2012 Share Posted January 3, 2012 Try instead: @echo off set "HOUDINI_PATH=C:\Program Files\Side Effects Software\hotbin_win64_H11.1.118_1.0rc9;&" set "PATH=C:\Program Files\Side Effects Software\hotbin_win64_H11.1.118_1.0rc9\dlls" start "C:\Program Files\Side Effects Software\Houdini 11.1.118\bin\hmaster.exe" Quote Link to comment Share on other sites More sharing options...
Netvudu Posted January 4, 2012 Share Posted January 4, 2012 Perfect! But it´s @echo off set "HOUDINI_PATH=C:\Program Files\Side Effects Software\hotbin_win64_H11.1.118_1.0rc9;&" set "PATH=C:\Program Files\Side Effects Software\hotbin_win64_H11.1.118_1.0rc9\dlls" start "" "C:\Program Files\Side Effects Software\Houdini 11.1.118\bin\hmaster.exe" with the extra "" after start or you stay at the command line instead of running the exe. Thanks for your patience! Now all my other Houdini versions work flawlessly and HOT runs nicely on this one. Quote Link to comment Share on other sites More sharing options...
Houart Posted January 8, 2012 Share Posted January 8, 2012 Hi everyone, I'm new to houdini, and I want to install the tool kit ocean, but don´t know how to create the environment variables, that I do within the software or system properties in control panel? Help me pls!! Quote Link to comment Share on other sites More sharing options...
Houart Posted January 8, 2012 Share Posted January 8, 2012 ok ok I hadn´t seen this thread. ¬¬! Quote Link to comment Share on other sites More sharing options...
Houart Posted January 8, 2012 Share Posted January 8, 2012 hotbin_win64_H11.0.446.9 someone who has? Quote Link to comment Share on other sites More sharing options...
