J.Santos Posted December 16, 2011 Share Posted December 16, 2011 (edited) Hi guys! The title may not be very explicit so I'll just explain what I'm (trying to) doing: I have a box (later on will be another object) that I'm breaking up using Voronoi fractures (make breakable) that uses in turn a magnet force, so I can have the look that something blew inside it. If I do the simulation in position 0,0,0 all is ok! If I try to do it somewhere in Y, like 4 units up, all hell breaks loose! So far I tried to: remove gravity - the object falls nonetheless... because of the RBD solver I guess; Constrain the object to a point in space - weird result with the object not breaking but instead wiggles around... Use a static object, with display turned off and active just in the 1st frames ( if $ST < 5, 1, 0)... this one works!!! -> yeah right... this is not my week... it keeps the object afloat however... the static object doesn't disappear so a couple of fragments sit in the air... Is there a better way? Some way to tell in the solver that it should ignore gravity for a couple of frames? Or should I keyframe the mass so the object "floats" in the said couple of frames??? Any thoughts would be great... I'm slowly loosing my mind with this! Cheers! Edited December 16, 2011 by J.Santos Quote Link to comment Share on other sites More sharing options...
mawi Posted December 16, 2011 Share Posted December 16, 2011 Is there a better way? Some way to tell in the solver that it should ignore gravity for a couple of frames? Or should I keyframe the mass so the object "floats" in the said couple of frames??? Keyframe or put a expression in the active parameter on the gravity node. Quote Link to comment Share on other sites More sharing options...
misterbil Posted December 16, 2011 Share Posted December 16, 2011 Could you post a sample scene? I have a similar problem but not sure. thanks Quote Link to comment Share on other sites More sharing options...
J.Santos Posted December 16, 2011 Author Share Posted December 16, 2011 Keyframe or put a expression in the active parameter on the gravity node. ... why was I thinking in complicated stuff...I'll try that one asap... but it sounds so logical... I need to check in my brain and ask another... right now I was trying to remove an object out of sim after a few frames... And yes, the if expression doesn't work because, as far as I'm aware, it checks if it's true or not and if it is, it creates/activates the object and doesn't check back... Thanks a lot mawi! misterbill @ I'll post you the scene as soon as I implement this solution, so you can have a working thing! Quote Link to comment Share on other sites More sharing options...
J.Santos Posted December 16, 2011 Author Share Posted December 16, 2011 (edited) well... somehow it doesn't work... same goes to exclude the object from being affected by gravity... it just falls! Any ideas? -> here's the file... I think this is going to take some time to solve probably because I made an error somewhere and now I'm paying for it... crackObject_07.hipnc Edited December 16, 2011 by J.Santos Quote Link to comment Share on other sites More sharing options...
mawi Posted December 16, 2011 Share Posted December 16, 2011 well... somehow it doesn't work... same goes to exclude the object from being affected by gravity... it just falls! Any ideas? -> here's the file... I think this is going to take some time to solve probably because I made an error somewhere and now I'm paying for it... Have not looked at your file, but another solution is to untick the active object in rbd object node and then use a active value DOP to key when being effected by forces. Quote Link to comment Share on other sites More sharing options...
J.Santos Posted December 17, 2011 Author Share Posted December 17, 2011 (edited) Hi mawi! I haven-t tried yet your idea because of this: the simulation (and destruction) is to start at frame 1, so I don't have a moment where it should be off and then on... Despite having my magnet force (metaball) parented to the object at SOP level, the thing is that the magnet doesn't follow the object so as soon as it starts to fall, it's like the magnet force just stops acting (but the thing is, it never acts...) I'm going to try and increase the sampling a bit so the cracking starts accurately at frame 1 and see what happens! Update: tried and... fail!!! Edited December 17, 2011 by J.Santos Quote Link to comment Share on other sites More sharing options...
J.Santos Posted December 17, 2011 Author Share Posted December 17, 2011 I just did a quick test in a new scene file and I'm starting to think this may be a bug... I'll test tomorrow a bit more but so far the object doesn't fall (gravity bypassed but still an active RBD Object) and it is cracking... however at the moment its not "exploding"... Quote Link to comment Share on other sites More sharing options...
mawi Posted December 17, 2011 Share Posted December 17, 2011 I just did a quick test in a new scene file and I'm starting to think this may be a bug... I'll test tomorrow a bit more but so far the object doesn't fall (gravity bypassed but still an active RBD Object) and it is cracking... however at the moment its not "exploding"... Something like this? fracture.hipnc Quote Link to comment Share on other sites More sharing options...
J.Santos Posted December 19, 2011 Author Share Posted December 19, 2011 Cool mawi! Exactly that! I spotted a few differences on your workflow that might have caused mine to not work as expected. I'll incorporate your solution into my scene and will post back the results! Thanks man! Quote Link to comment Share on other sites More sharing options...
J.Santos Posted December 19, 2011 Author Share Posted December 19, 2011 It's working perfectly thanks mawi! I'll post soon on the wip section my idea! Quote Link to comment Share on other sites More sharing options...
mawi Posted December 19, 2011 Share Posted December 19, 2011 It's working perfectly thanks mawi! I'll post soon on the wip section my idea! Glad it worked. Quote Link to comment Share on other sites More sharing options...
