ZeLemur Posted January 13, 2012 Share Posted January 13, 2012 I am sure i am just over thinking this however i believe i am just messing up searching and sorting a list with in a list Any Help would be appreciated. import math import random geo=hou.pwd().geometry() #x will equal total number of points x=10 LOOT = range(0,x) while len(LOOT) >= 0: #taking the list of the number of particles avalible and choseing one at random CP = LOOT[random.randrange(0,len(LOOT))] apart = [geo.points()[CP].position()] DistanceBP = [0,0] for l in range(0,len(LOOT)): N = LOOT[l] if N == CP: continue elif N != CP: bpart = [geo.points()[N].position()] qrt = math.pow(bpart[0][0]-apart[0][0],2) PW = math.pow(bpart[0][0]-apart[0][0],2)+math.pow(bpart[0][1]-apart[0][1],2)+math.pow(bpart[0][2]-apart[0][2],2) DistanceFinder = math.sqrt(PW) DistanceBP.append([DistanceFinder,N]) #sorting the distance to find the shortest distance and placing them in variables to be transfered to Tesselation DistanceBP.sort() P2a = DistanceBP[1][1]#<-- this is where the error is reporting a problem P3a = DistanceBP[2][1] P2= geo.points()[P2a].position() P3= geo.points()[P3a].position() #removing them from loot LOOT.remove(CP) LOOT.remove(DistanceBP[1][1]) LOOT.remove(DistanceBP[2][1]) Quote Link to comment Share on other sites More sharing options...
magneto Posted January 13, 2012 Share Posted January 13, 2012 I have to run the code to see it better but it seems like you are trying to index into an int, from your DistanceBP list. 1 Quote Link to comment Share on other sites More sharing options...
eetu Posted January 14, 2012 Share Posted January 14, 2012 My first reaction is that DistanceBP is a one-dimensional array of two-element tuples, but you're trying to access it like a two-dimensional array. Then again, the same seems to be happening with apart and bpart, and if they're working then I must be wrong.. (..or do they work because the first subscript is always 0?) 1 Quote Link to comment Share on other sites More sharing options...
ZeLemur Posted January 15, 2012 Author Share Posted January 15, 2012 My first reaction is that DistanceBP is a one-dimensional array of two-element tuples, but you're trying to access it like a two-dimensional array. Then again, the same seems to be happening with apart and bpart, and if they're working then I must be wrong.. (..or do they work because the first subscript is always 0?) I was under the impression that for apart that having brackets would allow me to declare apart as a tuple element. I have yet to test it but i guess that is over kill and python already recognizes it as a tuple from the .position call. Thus it places it in a array because of the brackets. My intention was to create DistanceBP and have that be a list which each element of the list contains two-element tuples. Thus allowing me to run a simple sort() on the distance and then utilize the second element of the tuple containing the points number. So, i guess my question would be where did i go wrong with that. Quote Link to comment Share on other sites More sharing options...
ZeLemur Posted January 18, 2012 Author Share Posted January 18, 2012 i found that the problem was with in my syntax and or with in what the variable that i called on creates. points()[pn].position() returns a vector3. Python has its own vector 3 class which will simplify most of my problems. Thank you all for you help. happy coding Quote Link to comment Share on other sites More sharing options...
