Macha Posted January 31, 2012 Share Posted January 31, 2012 (edited) I have tiny fast particles with motionblur but rather than smooth blurred lines I get irregularly dotted noisy ones. I tried upping pixels samples (>100), increase dicing, shading, no motionfactor, raytracing bias, pixel filter types, but I cannot get a smooth result. What else influences smooth motionblur? Edited January 31, 2012 by Macha Quote Link to comment Share on other sites More sharing options...
Macha Posted February 1, 2012 Author Share Posted February 1, 2012 Hmm. Seems like jitter to zero, and pixel samples up has a positive effect. Not perfect but helps. Quote Link to comment Share on other sites More sharing options...
ryew Posted February 1, 2012 Share Posted February 1, 2012 I can't speak from experience with Mantra for this problem, but with Renderman I've had to crank samples up to 24 or higher to get smooth results in the past (at which point I usually wondered if it would be worth just outputting motion vectors and doing it in comp instead) Quote Link to comment Share on other sites More sharing options...
eetu Posted February 1, 2012 Share Posted February 1, 2012 Which render engine? Quote Link to comment Share on other sites More sharing options...
Macha Posted February 1, 2012 Author Share Posted February 1, 2012 Micropolygon that is. Quote Link to comment Share on other sites More sharing options...
eetu Posted February 2, 2012 Share Posted February 2, 2012 I tried for a bit, but had no real luck either. Maybe scale per-pixel pscale, so that particle size in NDC is clamped to a minimum value? (still small, but not overly tiny..) Quote Link to comment Share on other sites More sharing options...
3dbeing Posted February 3, 2012 Share Posted February 3, 2012 Micropolygon that is. Did you try upping geo time samples? Quote Link to comment Share on other sites More sharing options...
