3dbeing Posted February 1, 2012 Share Posted February 1, 2012 Is it possible to do a volume lookup at render time using the volumeSampleFromFile and the op: syntax? Quote Link to comment Share on other sites More sharing options...
eetu Posted February 1, 2012 Share Posted February 1, 2012 Is it possible to do a volume lookup at render time using the volumeSampleFromFile and the op: syntax? The op: syntax needs the nodes inside Houdini. Picture mantra running on a renderfarm node, being fed an .ifd file, no Houdini installed. So, no. Quote Link to comment Share on other sites More sharing options...
3dbeing Posted February 1, 2012 Author Share Posted February 1, 2012 The op: syntax needs the nodes inside Houdini. Picture mantra running on a renderfarm node, being fed an .ifd file, no Houdini installed. So, no. Ok. I tried as simdata file and a obj, actually written out and it doesn't work. So I guess the better question is can I do a volume look up at render time? It seems volumeSampleFromFile isn't used in rop shop context? Quote Link to comment Share on other sites More sharing options...
symek Posted February 2, 2012 Share Posted February 2, 2012 Simdata won't work, but volume as bgeo works definitely. Promise. Did you converted camera space P into object space? See example (Render geometry ROP first). volsample.zip Quote Link to comment Share on other sites More sharing options...
3dbeing Posted February 2, 2012 Author Share Posted February 2, 2012 Simdata won't work, but volume as bgeo works definitely. Promise. Did you converted camera space P into object space? See example (Render geometry ROP first). I did not... Sweeet! You are a savior SYmek, thank you!!! Quote Link to comment Share on other sites More sharing options...
3dbeing Posted February 3, 2012 Author Share Posted February 3, 2012 Ok, so it's working except it throws an error 6 in the rop, right at the end. Obviously this is a problem for the farm. I notice yours does too. Do you get this error in the rop node when you render? Quote Link to comment Share on other sites More sharing options...
symek Posted February 3, 2012 Share Posted February 3, 2012 Ok, so it's working except it throws an error 6 in the rop, right at the end. Obviously this is a problem for the farm. I notice yours does too. Do you get this error in the rop node when you render? I got no errors, except a warning of missing light. Quote Link to comment Share on other sites More sharing options...
