ykcosmo Posted November 3, 2003 Share Posted November 3, 2003 Last time ,I post a topic on this site, that problem was I can't install houdini 6 for linux7.X on linux 8. but now, I installed red hat linux 7.3, and still had the same problem.when I finished installing houdini 6.0340. and then "source houdini_setup_bash", and then type "hkey", it appeared, but when I click on "file" and wanted to enter the lincense, hkey shutted down...... people said that was the linux 8.0's fault ,and ,houdini only run under linux 7.x, so I have linux 7.x installed, why I have the same problem?? and what should I do now?? Thank you ! Quote Link to comment Share on other sites More sharing options...
stevenong Posted November 3, 2003 Share Posted November 3, 2003 I guess I'll post the link to my reply here too! http://www.sidefx.com/forum/viewtopic.php?t=1890 Cheers! steven Quote Link to comment Share on other sites More sharing options...
ykcosmo Posted November 4, 2003 Author Share Posted November 4, 2003 I used GeForce 2 mx and use the defaut driver of linux installing. and , would I run maya under it? Quote Link to comment Share on other sites More sharing options...
tallkien Posted November 4, 2003 Share Posted November 4, 2003 The default redhat installation uses the "nv" driver if I'm not mistaken and it does not support OpenGL. You should download the latest driver from the nvidia site. Your driver should be called "nvidia" Quote Link to comment Share on other sites More sharing options...
mark Posted November 25, 2003 Share Posted November 25, 2003 if it helps, I can tell you Apprentice runs on mandrake 9.2 and gentoo with geforce2, it's XSI that will not run on newer (> RH7.2) distros. I was disappointed about xsi, but im glad it didnt work - it made me get stuck into houdini ... ironic Quote Link to comment Share on other sites More sharing options...
