dynamoanders Posted February 29, 2012 Share Posted February 29, 2012 Hi guys. I just can´t get my head wrapped into this (coming from Maya). How can I control my color with a ramp (or opacity or reflectivity)? In Maya, if I want something like a fresnel effect, I just plug a ramp into the reflectivity input and control the color from there. I was thinking of doing something like having the opacity strong in the middle of my object, and getting weaker towards the end, trying to use the default clay shader , plugging a ramp into the reflectivity. How do I do this? Thank you //Anders Quote Link to comment Share on other sites More sharing options...
kare Posted February 29, 2012 Share Posted February 29, 2012 Hi Anders, In SOP's : you can add vopsop and add ramp node inside of vopsop and give output of ramp parameter to color attribute. If you want to control opacity, create a add attribute node inside of vopsop and in parameters give opacity as the attribute name and connect ramp parameter to output to its input. Quote Link to comment Share on other sites More sharing options...
Macha Posted February 29, 2012 Share Posted February 29, 2012 (edited) You can get a vector from the point to be shaded to the camera. If you dot that with the normal you get the cosine of an angle and can drive a ramp with and output either a float or a color. There is also a ready made fresnel node. Edited February 29, 2012 by Macha Quote Link to comment Share on other sites More sharing options...
papicrunch Posted February 29, 2012 Share Posted February 29, 2012 You can use also Normal falloff in shop that mimic a maya "facing ratio" Have fun, Thomas Quote Link to comment Share on other sites More sharing options...
