custom variables
Please see the attached example scene. I ve setup a custom attribute which is getting mapped as a custom variable. Could someone please explain how to use that custom variable for further simple operations. I thought setting a parameter $VARIABLE should work but ... ?
Thank you
HT
pointdistance_v01.hip
Edited by hatrick
and how about a transform sop ... i.e how to drive the scale parameter. i ve no specific goal here, just a matter of interest.
Try promoting it to class detail and use it.
Transform sop needs a single value for the entire geometry.
Cheers,
