Reference grids and images.
Stremik
Turn off apply operations to all split views, press "d" in the viewport you want to apply the image to and in the background page browse to your image, then do the same for the other viewports. You can have different images in different ortho views. Not sure how to get them all in perspective.
You could map textures onto grids ofcourse, actually that would be better since you can scale them to your needs. I you need to work in wireframe, just template the grids and change the template object settings to be full shaded
