Learning fluids
Ezz
Hi all good Houdini-folks.
With the introduction af Houdini 12 it has become very fun to simulate fluids.
I have done some productionsimulations in Maya and have experienced the pain it
is to achieve a good result. So I have been avoiding fluids for a while.
But now I am keen to learn not just the basics, but try to get a bit futher down the
rabbithole. I have worked a bit with Naiad and enjoyed the ease of using custom attributes
Normals, Color etc. as fields to drive some simulationparameters.
I need to get the same understanding in Houdini, but I am overwhelmed a bit about the complexity
and different approaches here.
I have a lot of questions like: "how can I controle a fluids velocity with colorinformation and normals from an object" and
so on.
I really need some basic understanding.
Does anyone of you know a good start, tutorial or paper that can enlightening me?
Thank you very much.
Erik
Hi Edward.
Thank you very much for your answer.
Still I find it very very intimidating. I guess its the nature of Houdini to be open as posible, but it sure
is hard to get my head around all this.
I will hope for a good tutorial on CmiVfx or like to crack this open for me :-(
So I have been doing some reseach on how Houdini fluids are working. At first I was intimidated by the complexity of the inbuild solvers.
But going throug Coens example helped me a lot. Thanks Coen :-)
I have a better understanding of the concept with fields etc.
I have reverse engineered Coen setup for better understanding and it has giving me a faily good result. But I still miss a lot of extra bling bling ;-)
Here is a quick render of my sim:
Also I will attach my setup. I would really like to see some people come with some changes and suggestion to improve the setup. This could be an awsome post :-)
Cheers
Erik
eriks_fluidsolver_build_v01.hipnc
Oh, doing this is surely a wonderful learning experience!
(*scribbles into todo-list*)
Some comments
- in your source fields, confinement, divergence and pressure do not have their Data Fields set, I suppose they should be named accordingly? (also, pressure has a bad explicit sop path for division size)
- I think it would be easier to create the fields with a Gas Match Field DOP, so you would not need to bother with all the linking
- add_velocity has a bad explicit sop path
- looks like you're advecting velocity with itself twice? ("gasadvectfield1" and "velocity_advect")
- I used to do the same as you, put parameters on a master null and link to them. Creating a subnet and putting the controls on the subnet level is a better practice in case you want to Assetize your stuff.
Hi Eetu - You are ace !
Thank you very much for your suggestions. I have fixed the things you mention, and it allready looks better.
I have a couple of questions about the naming of the created fields like "pressure","confinement" etc.
How can I know wich microsolvers looks for these fields ?
Well "density","temperature","vel" is obviuos!
Also I have used the Volumefromattrib-SOP. Is that a new SOP in 12?
In the examples from Coen and Peter Claes they use
their own custom digital asset to transfer point-attributes to either scalar-fields or vector-fields.
Cheers Erik
eriks_fluidsolver_build_v02.hipnc
Edited by Ezz
