eloop Posted April 24, 2012 Share Posted April 24, 2012 (edited) Hi people, Sorry I've been absent from most of the recent discussion, I'm very busy on other things these days. Thanks to Nicholas Yue SOP_Ocean now works under H12 using the new GA geometry libraries. I've also started to move away from google code and onto Github which is where ongoing (>= H12) development will take place. Finally I'm changing the way things are compiled and installed, no more producing binary distros, hopefully simpler. For the adventurous among you (Linux and OSX only) , grab the latest code from https://github.com/eloop/hot Compile and install it with the new shell script > ./compile.sh If the 3rdparty dependencies have been compiled (via the above script) you can bypass doing it again by > ./compile.sh -f Finally if you just want to test building and not install to $HOME/houdini12.0 use the -n flag. >./compile.sh -n It will be useful if people report their experiences building in this thread. For anyone who wanted to write the equivalent "compile.bat" for windows, I'd be happy to add it to the distribution. Cheers, Drew Edited April 24, 2012 by eloop 3 Quote Link to comment Share on other sites More sharing options...
fsimerey Posted April 24, 2012 Share Posted April 24, 2012 (edited) Hi people, Sorry I've been absent from most of the recent discussion, I'm very busy on other things these days. Thanks to Nicholas Yue SOP_Ocean now works under H12 using the new GA geometry libraries. I've also started to move away from google code and onto Github which is where ongoing (>= H12) development will take place. Finally I'm changing the way things are compiled and installed, no more producing binary distros, hopefully simpler. For the adventurous among you (Linux and OSX only) , grab the latest code from https://github.com/eloop/hot Compile and install it with the new shell script > ./compile.sh If the 3rdparty dependencies have been compiled (via the above script) you can bypass doing it again by > ./compile.sh -f Finally if you just want to test building and not install to $HOME/houdini12.0 use the -n flag. >./compile.sh -n It will be useful if people report their experiences building in this thread. For anyone who wanted to write the equivalent "compile.bat" for windows, I'd be happy to add it to the distribution. Cheers, Drew So Great !! Edited April 24, 2012 by fsim Quote Link to comment Share on other sites More sharing options...
fsimerey Posted April 24, 2012 Share Posted April 24, 2012 (edited) Hi, first of all, thanks for your work. I tested on Mac OS X (10.6.8). First, under os X, the default preferences folder is in /Users/nameofuser/Library/Preferences/houdini/12.0 when your install script create a new folder in /User/nameofuser/houdini12.0 Second, with Ocean SOP, if you uncheck Chop toggle, the ocean doesn't have effect. All is ok with a VEX node. When you promote parameters in a VOP/SOP, like the previous version, the Height Scale Label, will promote as 'Input 1' instead of 'Height Scale' and give a default value of 10000 for Ocean Size. i will test under linux. Edited April 24, 2012 by fsim Quote Link to comment Share on other sites More sharing options...
fsimerey Posted April 24, 2012 Share Posted April 24, 2012 I have some strange results with some parameters only for 1 frame. See attached. and another bug is a back frame in simulation. Quote Link to comment Share on other sites More sharing options...
Green-Man Posted April 25, 2012 Share Posted April 25, 2012 Compiled and works fine at: CentOS 6, gcc4.4, h12.0.595 Thank you! Quote Link to comment Share on other sites More sharing options...
Naeem Posted April 25, 2012 Share Posted April 25, 2012 Compiled and works fine at: CentOS 6, gcc4.4, h12.0.595 Thank you! Hi, Could someone compile a version for Houdini 12.0.581 for Ubuntu x64 or give more detailed instructions on how to go about it? Thanks. Quote Link to comment Share on other sites More sharing options...
eloop Posted April 26, 2012 Author Share Posted April 26, 2012 (edited) Thanks for the feedback. I've verified the chop toggle problem, yet to look into the parameter promotion problem. Not sure about the installation directory. I know that I'm always having to look up where the hell things are being installed on Mac and find it much easier to have things in $HOME/houdini12.0 (ie $HIH in the old days). What do others think ? It's easy enough to change, just remove the -i $HIH/dso bit in the compile script. -Drew Hi, first of all, thanks for your work. I tested on Mac OS X (10.6.8). First, under os X, the default preferences folder is in /Users/nameofuser/Library/Preferences/houdini/12.0 when your install script create a new folder in /User/nameofuser/houdini12.0 Second, with Ocean SOP, if you uncheck Chop toggle, the ocean doesn't have effect. All is ok with a VEX node. When you promote parameters in a VOP/SOP, like the previous version, the Height Scale Label, will promote as 'Input 1' instead of 'Height Scale' and give a default value of 10000 for Ocean Size. i will test under linux. Edited April 26, 2012 by eloop Quote Link to comment Share on other sites More sharing options...
Green-Man Posted April 26, 2012 Share Posted April 26, 2012 (edited) Hi, Could someone compile a version for Houdini 12.0.581 for Ubuntu x64 or give more detailed instructions on how to go about it? Thanks. I don't know the version of Ubuntu you use and version of gcc. But there is a chance that it will help you. This SOP_Ocean.so works for me on both on Houdini 12.0.595 and 12.0581 under Centos 6 (gcc-4.4) and Fedora 16 (gcc-4.6). I don't know how to find out the version of the source code which I compile from. But its a clone of the git (https://github.com/eloop/hot) from 25 of april 2012 And I have the VEX_Ocean.so from the other sources that works on the same configurations. I made it by following the instructions of Hans Joergen from this post here And yes this SOP_Ocean seems to doesn't work at all without Chop toggle turned on. SOP_Ocean.so_12.0.595_gcc-4.4.tar.gz VEX_Ocean.so_12.0.595_gcc-4.4.tar.gz Edited April 26, 2012 by Green-Man Quote Link to comment Share on other sites More sharing options...
Naeem Posted April 26, 2012 Share Posted April 26, 2012 I don't know the version of Ubuntu you use and version of gcc. But there is a chance that it will help you. This SOP_Ocean.so works for me on both on Houdini 12.0.595 and 12.0581 under Centos 6 (gcc-4.4) and Fedora 16 (gcc-4.6). I don't know how to find out the version of the source code which I compile from. But its a clone of the git (https://github.com/eloop/hot) from 25 of april 2012 And I have the VEX_Ocean.so from the other sources that works on the same configurations. I made it by following the instructions of Hans Joergen from this post here And yes this SOP_Ocean seems to doesn't work at all without Chop toggle turned on. Thanks a lot, this works perfectly. Quote Link to comment Share on other sites More sharing options...
eloop Posted May 7, 2012 Author Share Posted May 7, 2012 I just fixed the problem with chop turned off, update from the github repo. -Drew Hi, first of all, thanks for your work. I tested on Mac OS X (10.6.8). First, under os X, the default preferences folder is in /Users/nameofuser/Library/Preferences/houdini/12.0 when your install script create a new folder in /User/nameofuser/houdini12.0 Second, with Ocean SOP, if you uncheck Chop toggle, the ocean doesn't have effect. All is ok with a VEX node. When you promote parameters in a VOP/SOP, like the previous version, the Height Scale Label, will promote as 'Input 1' instead of 'Height Scale' and give a default value of 10000 for Ocean Size. i will test under linux. Quote Link to comment Share on other sites More sharing options...
eloop Posted May 8, 2012 Author Share Posted May 8, 2012 I don't see this (on OSX), do you see the same thing with the vopsop_foamparts.hip example ? -Drew I have some strange results with some parameters only for 1 frame. See attached. and another bug is a back frame in simulation. Quote Link to comment Share on other sites More sharing options...
fsimerey Posted May 15, 2012 Share Posted May 15, 2012 I don't see this (on OSX), do you see the same thing with the vopsop_foamparts.hip example ? -Drew No, i don't see this issue on this example file, but the easy way to see it, it's to add a trail sop to compute the velocity, play with the Chop amount, and play the sequence with velocity diplayed. Sometimes, the velocity come very large for one frame. In fact, when i fall on this, if i Force recompile the VOP/SOP or i quit and reopen my scene, the problem disappear. My last tests were done on linux x64 and the build 12.0.616. Quote Link to comment Share on other sites More sharing options...
fsimerey Posted May 15, 2012 Share Posted May 15, 2012 Here an example HOT_test.mov Quote Link to comment Share on other sites More sharing options...
nran Posted July 10, 2012 Share Posted July 10, 2012 hi guys, IS anyone know where is my HDK?? root@nKC320-desktop:/opt/hfs12.0.581/HOT_for_H12# ./compile.sh We can't see the HDK, exiting. how can i make compile.sh know where is the HDK located? Thanks in advance Quote Link to comment Share on other sites More sharing options...
fsimerey Posted July 10, 2012 Share Posted July 10, 2012 hi guys, IS anyone know where is my HDK?? root@nKC320-desktop:/opt/hfs12.0.581/HOT_for_H12# ./compile.sh We can't see the HDK, exiting. how can i make compile.sh know where is the HDK located? Thanks in advance Before compile, you must source houdini: cd /opt/hfs12.0.581 source houdini_setup Quote Link to comment Share on other sites More sharing options...
nran Posted July 10, 2012 Share Posted July 10, 2012 (edited) Before compile, you must source houdini: cd /opt/hfs12.0.581 source houdini_setup Thanks your reply, looks like i only got half way through it, g++ -shared SOP_Ocean.o -L/usr/X11R6/lib64 -L/usr/X11R6/lib -I. -I./3rdparty/include -I./3rdparty/linux/include -L./3rdparty/linux/lib -lfftw3f -lblitz -lGLU -lGL -lX11 -lXext -lXi -ldl -o /USERS/KC300/houdini12.0/dso/SOP_Ocean.so /usr/bin/ld: cannot find -lblitz collect2: ld returned 1 exit status Link failed "cannot find -lblitz" what's this file is? and where i can get this guy in my ld? Can i go ahead to install Blitz++ to fix this? SORRY for this, i have found out "2. Compiling programs All Blitz++ header files are referred to with a prefix of "blitz/". For example, to use the Array<T,N> class, one needs to include <blitz/array.h> instead of just <array.h>. To make this work, the main Blitz++ directory must be in your include path. For example, if Blitz++ was installed in /software/Blitz++, you will need to compile with -I/software/Blitz++ and -L/software/Blitz++/lib -lblitz To summarize, a typical command line is: g++ foo.cpp -o foo -I/software/Blitz++ -L/software/Blitz++/lib -lblitz To avoid the -I and -L options, you can set up symbolic links -- see INSTALL for details. Thanks~~~~~ Edited July 10, 2012 by nran Quote Link to comment Share on other sites More sharing options...
nran Posted July 12, 2012 Share Posted July 12, 2012 got successfully compiled under Ubuntu 11.04, H12.0.683, works great! thanks eloop!! Quote Link to comment Share on other sites More sharing options...
