Cookie on Copy SOP geo?
Benjamin Fiske
I'm trying to make a very basic polygonal cloud. I'm starting with an isooffset'd sphere, scattering points on that, and then copying a bunch of randomly sized polygonal spheres to that point cloud via the copy SOP.
Having never used the cookie SOP before, is there a simple way to take all of this resulting geo and cookie each into one uniform surface?
You could optionally use an isooffset to convert all the spheres to an isosurface.
If you must use a cookie sop you might have to set it up inside a foreach sop cause the cookie only takes two objects at a time. it could be a bit confusing a setup, plus nothing guarantees that the cookie won't corrupt your geo at some point...
Take a look at Peter Quint's videos on the foreach sop if you decide to go down that route.
Cheers
Edited by rafaelfs
Cheers
I thought of isooffset last night, as well, but the result was a swiss cheese mesh. I'm guessing it has a tough time navigating which part is inside and which part is outside in a big mess of geo like that.
Tried foreach last night as well, but it didn't seem (offhand) that one could grab the "next each" to use - nor would that necessarily work. Ideally this would be solved in a system that progresses from the first and ends at the last, but that's pretty un-Houdini .. tricky problem!
without volumes .
oc , the Merge Results option on the ForEach node is turned OFF
since the cookie operation mode ( Union ) adds them all by itself .
well , the cookie ' accuracy ' .. is another song . =)
scene is a H11 file . while Clip SOP is just to see whats going on inside ..
cloudz.hipnc
.cheers
I'll just throw this in here, if you set a metaball to Threshold Radius with a weight of 10 it almost exactly matches a sphere of the same radius when you isoOffset it in metaball mode. On my last show I had a simple asset that contained a linked metaball and sphere so I could pop it down and model with primitive spheres then select all of them and toggle to metaballs for the isoOffset.
