Camera XY Pos of Points at SOP level
Hey all,
I need to save the XY pos in camera space of some points at SOP level.
So from left to right will be 0-1, bottom to top 0-1 of the point in camera space saved as a point attribute.
I would have thought it could have been done with a transform in VOPSOPs, but I'm not sure exactly of the syntax to use, if indeed it works at all.
Any ideas?
Thanks
Christian
P.s. I've attached a simple scene to show you what I mean.
cameraXYSOP.hip
I got the green (y) component to work but the red (x) and blue (z) need to have something done to them, not sure what at the moment...
EDIT: This is pretty much it, the x values seem a little odd, you probably have to remap x and y to your aspect ratio as the coordinates appear to be in more of a 1:1 ratio currently.
cameraXYSOP_almost.hipnc
Edited by jkunz07
