cloudfx Posted May 23, 2012 Share Posted May 23, 2012 Hi, I have a grid and uv attribute using cam project. I attribute copied uv from the grid's first frame time shift(locked to frame 1) since I am animating the grid but want to have the uv data at frame 1. It is working so far but once I delete some point on the grid, the uv order get messed up since the point number get changed. How would I fix this/work around this? Thanks, Quote Link to comment Share on other sites More sharing options...
sadhu Posted May 23, 2012 Share Posted May 23, 2012 Take a grid with no animation as you want uvs when frame no is 1, apply texture first. Then perform operations like deleting or animating the grid. Quote Link to comment Share on other sites More sharing options...
eetu Posted May 23, 2012 Share Posted May 23, 2012 (edited) Are you sure you really need to copy the attribute? Sounds like you could just do the UVProject on the base mesh before any animation. If you really need to, you could add an id attribute to the base mesh, with an initial value of $PT. Then copy your uvs with a point("../timeshift1", $ID, "uv", 0 ) etc edit: ohh, sadhu was faster Edited May 23, 2012 by eetu Quote Link to comment Share on other sites More sharing options...
cloudfx Posted May 23, 2012 Author Share Posted May 23, 2012 Are you sure you really need to copy the attribute? Sounds like you could just do the UVProject on the base mesh before any animation. If you really need to, you could add an id attribute to the base mesh, with an initial value of $PT. Then copy your uvs with a point("../timeshift1", $ID, "uv", 0 ) etc edit: ohh, sadhu was faster Yes, I did deleting after the uv copying to my original mesh with rested position. I am getting my mesh from cloth solver, and when it tears off point number gets increased. I solved this problem with attribute copy to Vertices, not Points and it is now working. Thanks ! Quote Link to comment Share on other sites More sharing options...
