cloudfx Posted May 24, 2012 Share Posted May 24, 2012 getting wireframe as edge line. Like add sop has "Delete Geometry But Keep the Points" but only edges. Is there any? Quote Link to comment Share on other sites More sharing options...
cloudfx Posted May 24, 2012 Author Share Posted May 24, 2012 getting wireframe as edge line. Like add sop has "Delete Geometry But Keep the Points" but only edges. Is there any? tried add sop and connected each 2 point that makes wireframe with add sop under Polygons tab's By Pattern but let me know if there is any others. Quote Link to comment Share on other sites More sharing options...
Darric Posted May 25, 2012 Share Posted May 25, 2012 This is sort of crude, but here's something hacked together using the Wireframe SOP as a starting point: wireframe.hip 1 Quote Link to comment Share on other sites More sharing options...
Darric Posted May 25, 2012 Share Posted May 25, 2012 I'm surprised this isn't an available option on the Wireframe SOP actually. Quote Link to comment Share on other sites More sharing options...
3dbeing Posted May 25, 2012 Share Posted May 25, 2012 You can use the ends sop and turn on unroll 2 Quote Link to comment Share on other sites More sharing options...
eetu Posted August 8, 2012 Share Posted August 8, 2012 I just had to do this lately, and the easiest way I found was; Wireframe SOP, 0 width, no rounding Convert SOP, to polygons with "Columns" connectivity Fuse SOP, if needed. This creates a polyline per edge - Ends SOP is nice, but it creates a polyline per primitive. (Of course sometimes that might be what one needs) 3 Quote Link to comment Share on other sites More sharing options...
