smoke can't collide with moved object
sparkChan
Hi , I did check the network.
I did not see how to get it to collide there,
How ever I did mess around inside the DOP network .
There msut be something that we are overlooking . You mentioned that you used the selfs.
Antway here is a method that will collide with the pyro
mangi
smoke_box_collide.hip
mangi
thanks for your reply.
I used the 'Collide with Objects' in the 'Populate Containers' tab to do the job.so it's the same with rbd object.
it works when the cube stops, but when it moves, it not.
I do the same setup in H11, and check 'Use Volume Velocity for Collisions' in the 'Collisions' tab under the 'Relationships', it works.
I don't know why.
thanks.
when the cube is moving, it just like the cube is sinking the smoke.
but when it stops, the collision is right.
bacause your box is a deformed obj, you should add vel information to it or istead your deformed obj to transformed obj.
actually I'v added vel to it, but it doesn't change a lot.
thanks
Edited by sparkChan
Cool. it aactually works if you use a RBD to movee the object
thanks for that detail
mangi
RBD_box_collide.mov
Edited by mangi
Cool. it actually works if you use a RDB to move the object
mangi
It would be cool to see if we could figure out sparkChan method
mangi
Edited by mangi
  • 7 months later...
hi, I don't know why the smoke can't collide with moved object, and it's just like sinking the smoke not colliding. I just used the shelf tool to set up simulation.
thanks.
Hi sparkChan, since in H12 the projection method changed to multigrid, there some slight issues with collision. Multigrid is much faster than old method but less accurate, so try to increase multigrid iteration in order to get more accurate collisions.
  • 1 month later...
