Getting sss to work with point instance procedural
Hey guys,
I was hoping someone could enlighten me as to why I can't get sss to work with the point instance procedural. I'm using pbr. If I turn all components of the surface shader off except for sss and try single scatter the instance object renders black. If I attempt to render with multi scatter the render seems to get stuck on generating the point cloud.
Thanks
Mike
Hey guys,
Thanks
Mike
Do you have an example file we could try ?
  • 3 weeks later...
This was in today's journal:
Houdini 12.0.663: Fixed sub-surface scattering to work with point instancing by introducing a new scope, "scope:self", which allows scopable raytracing operations to safely restrict themselves to only the currently shading object.
