How to blur point colors?
Thanks alot guys, super useful. I didn't inspect Smooth SOP enough to realize it had options to blur colors and other attributes :)
But that made me also curious as to whether you could achieve other types of blurs. Like what about radial blur? Pretty sure this is not built-in, right? If not, then how would you do it? VOPs?
Also in the case of Radial Blur, just like the Smooth SOP, I am thinking of being able to apply to any attribute.
EDIT: That attribute blur OTL is great and pretty fast too. I can't see which line in the code does the blurring though.
Edited by magneto
You could also use and attribute transfer sop and wire the your colored grid into both inputs. Then make sure you set it to sample from more than 1 point and play with the radius a bit.
