glfloat Posted September 27, 2012 Share Posted September 27, 2012 No matter what I do I cannot ge tthis sim to stop blowing up. Seems like for any somewhat complex shapes bullet is extremely unstable. If someone, anyone, can try to get these scene to sim stable (eg: the pieces on the cube dont fly out on their own) I would appreciate that. So far my tests have prooven that bullet is far from production ready. But I'd love it if one of you could just tell me that I should stop complaining and learn how to use houdini 1 Quote Link to comment Share on other sites More sharing options...
glfloat Posted September 27, 2012 Author Share Posted September 27, 2012 see attached bullet_popping_odforce.hipnc 1 Quote Link to comment Share on other sites More sharing options...
woodenduck Posted September 27, 2012 Share Posted September 27, 2012 If you drop the uniform scale in the foreach down to 0.75, you no longer get the popping. So I would guess that because bullet uses a less accurate collision detection than Houdini RBD it thinks parts of the geo are intersecting at the first frame, causing it to behave erratically. You can see this if you check out the collision geometry in the dopnet. I guess less accuracy is the price you pay for faster sims, and this is one of the drawbacks. Perhaps increasing the uniform divisions on the collision geo might clear things up a bit? Quote Link to comment Share on other sites More sharing options...
eetu Posted September 27, 2012 Share Posted September 27, 2012 Also, untick the "geometry as convex hull" or something along those lines, found in the bullet collision object parameters. Quote Link to comment Share on other sites More sharing options...
glfloat Posted September 29, 2012 Author Share Posted September 29, 2012 yea none of that really worked. Checking geometry as convex hull worked a little. Shrinking the collision guide geometry in dops did nothing.. Im assuming bullet does not use the SDF technique for its collisions so I might be looking in all the wrong places? Does anyone have a setup with fractured geo that actually works? And I dont mean voronoi fracturing.. I mean something with some more complex geo like the one I posted. Quote Link to comment Share on other sites More sharing options...
Marc Posted September 29, 2012 Share Posted September 29, 2012 Hey I haven't looked at your file, but just quickly. Bullet generates a convex hull proxy geo for the collision detection phase. Which means if you have any concave parts of your geo then they will register as intersections. Bullet has a concave collision detection method, but it's pretty flaky. The best way we've found of working is to make sure that all your chunks are convex and then put in time to glue together sections to create more complex shapes that don't freak out bullet . One day I may have time to whip up an example file, but that should be enough to send you in the right direction. M Quote Link to comment Share on other sites More sharing options...
glfloat Posted October 2, 2012 Author Share Posted October 2, 2012 Interesting Marc, ok that explains a lot of things. What is your workflow for insuring all geo is convex out of a voronoi fracture? Is it as simple as going through each chunk in a foreach and convexifying it. I'd imagine you'd still have strange geo that way as they may not "fit" together. or Im assuming you guys have custom tools for that.. Quote Link to comment Share on other sites More sharing options...
eetu Posted October 2, 2012 Share Posted October 2, 2012 The way a voronoi fracture is defined means that all the chunks are already convex. Quote Link to comment Share on other sites More sharing options...
Marc Posted October 2, 2012 Share Posted October 2, 2012 yeah exactly. If you're getting non-convex shapes out of your voronoi fracture (I've seen it happen, but very rarely), then just try and re-arrange your input points a little. We don't really have custom tools for that side of things. Although if you feel brave you can try and get Allen Johns' vfxgal working: https://github.com/nerdvegas/vfxgal It was implemented for us at Dr D and is significantly faster than the built in voronoi fracture. M Quote Link to comment Share on other sites More sharing options...
cubiccube Posted October 3, 2012 Share Posted October 3, 2012 The problem is that you're clustering from within the Voronoi Fracture SOP. By doing this you're essentially creating non-convex shapes that Bullet is going to freak out over. The proper workflow for clustering with Bullet is to use the Glue Pieces and Glue Cluster SOPs to build a glue network that you then reference from within DOPs using a Glue Network Constraint DOP. Check out the file below. I used the "Glue Adjacent" shelf tool to set up the initial glue net before tweaking it (initial settings tend to be overkill) and adding a Glue Cluster SOP. It's also important to note that I've locked the Glue Pieces SOP so that it doesn't recook anytime you change something. You will need to unlock it and let it cook anytime you add or remove something in DOPs that generates a dopobjectid. So if you want to see the fractured cube without the breaker geo, for example, then you need to disable the "rbd breaker," go unlock/cook/re-lock the Glue Pieces SOP and probably do a reset on your DOP net or else the Glue Network is going to get confused (you'll be able to see this if you have its guide geometry enabled). Oh, and I turned on "connect edges" on the Voronoi Fracture. You should probably always do this or else you're likely to get unexpected results from DOPs or SOPs down the line that run a connectivity check on your geometry as it will treat each face as a piece instead of each piece as a piece. bullet_popping_fixed_01.hipnc 1 Quote Link to comment Share on other sites More sharing options...
anupamd Posted October 4, 2012 Share Posted October 4, 2012 cubicube.. this is an amazing file. I am disecting this now.. thanks so much! Quote Link to comment Share on other sites More sharing options...
cubiccube Posted October 5, 2012 Share Posted October 5, 2012 No problem..glad it's helpful. Have a look at this thread too: http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=20909. Buried in there are some great tips and example files dealing with bullet glue nets. Quote Link to comment Share on other sites More sharing options...
acc3d Posted April 27, 2014 Share Posted April 27, 2014 Hi cubiccube, I've been trying to troubleshoot some annoying jitter in my own Bullet sim and came across your example file above. The problem with my sim seems to be thin pieces combined with what I believe is a bug in the 'RBD Packed Object' OTL. With the 'show guide geometry' turned on and 'display geometry' off, you can see that it's regenerating every frame (use smooth or flat wire shaded). Simulate long enough to the pieces settle, then you'll see the guide geometry change topology. Is this a bug in SideFX's OTL? Can somebody look at the attached file and tell me if I've made a mistake somewhere? Thanks, AC bullet_packed_rbd_retopologize_01.hipnc Quote Link to comment Share on other sites More sharing options...
pgrochola Posted May 3, 2014 Share Posted May 3, 2014 yes! I just posted a new thread about this. Quote Link to comment Share on other sites More sharing options...
