dennisvolkerts Posted October 18, 2012 Share Posted October 18, 2012 Is there a posibility to calculate substeps on a cache file? I have tried to used time warp for stretching the cache for example from frame 1 in to -> to 1 to 50 but it just gave me frame first or the second frame. for example: i shatter a glass thats falling using fractureparms with 25fps. now i want to use it at 300fps or also i want to use the cache to be a collision on later aplied water simulations thnx http://youtu.be/h2GupSHP_oM Quote Link to comment Share on other sites More sharing options...
gui Posted October 18, 2012 Share Posted October 18, 2012 try tu use a time blend sop and than a time shift (multiply the expression by a number > 1) I hope it helps! Quote Link to comment Share on other sites More sharing options...
sam.h Posted October 18, 2012 Share Posted October 18, 2012 (edited) You can use a timeblend node before the timewarp to interpolate between the frames ....too slow! Edited October 18, 2012 by sam.h Quote Link to comment Share on other sites More sharing options...
Macha Posted October 18, 2012 Share Posted October 18, 2012 (edited) Or a chop network if your points have id and are not in millions. Is even slower, but more control. Edited October 18, 2012 by Macha Quote Link to comment Share on other sites More sharing options...
Darric Posted October 18, 2012 Share Posted October 18, 2012 If you use a timeshift (I much prefer this to using timewarp, I normally just create a curve for my Frame parameter) make sure you uncheck "Integer Frames". Quote Link to comment Share on other sites More sharing options...
dennis.albus Posted October 19, 2012 Share Posted October 19, 2012 (edited) I would also vote for the timeshift technique with an animated frame parameter as Darric suggested. If you are using any kind of dynamic fracturing you need to make sure to generate unique ids. To do this I normally use a combination of point numbers and $DOPOPJECTID (make sure you enable this in your dopimport). To get consistent point numbers I separate each piece with a for each node. I've attached an exemplary hip file with the important parts to show you the nodes and expressions I use. To work efficiently with this be sure to cache your simulation first -dennis dynamic_retime.hip Edited October 19, 2012 by dennis.weil Quote Link to comment Share on other sites More sharing options...
dennisvolkerts Posted November 7, 2012 Author Share Posted November 7, 2012 I would also vote for the timeshift technique with an animated frame parameter as Darric suggested. If you are using any kind of dynamic fracturing you need to make sure to generate unique ids. To do this I normally use a combination of point numbers and $DOPOPJECTID (make sure you enable this in your dopimport). To get consistent point numbers I separate each piece with a for each node. I've attached an exemplary hip file with the important parts to show you the nodes and expressions I use. To work efficiently with this be sure to cache your simulation first -dennis thnx... im not that familiar with houdini jet. you sayed: If you are using any kind of dynamic fracturing you need to make sure to generate unique ids. well im working with a cached file. Is it then still posible to generate the unique ids if you dont have the dynamics anymore? thnx Quote Link to comment Share on other sites More sharing options...
ikarus Posted November 13, 2012 Share Posted November 13, 2012 If you didn't stamp the dopobjectid then yes you will have to rerun the sim. Quote Link to comment Share on other sites More sharing options...
