3D Room Render
Daniel_123
I used Maya for modeling and Houdini for everything else. I exported just a beauty pass using Houdini`s Mantra renderer. For post processing I used After effects, but only for small color tweaks.
The entire project took about 2 weeks and it mainly involved learning how to achieve a realistic look. The last 3 days were focused just on balancing the materials, lights and textures to achieve the final feel.
post-7551-0-32421300-1351686571_thumb.jp
post-7551-0-60574400-1351686541_thumb.pn
Feedback and questions are appreciated.
Edited by Daniel_123
beautiful! How long was the render time and what was the specs of the mantra & system?
Hey, thanks.
The final render took around 9 hours, but I think I bumped up the pixel samples probably a bit too much for the PBR. Pixel samples 20 x 20, image resolution 1600px x 1080px.
Other info:
Diffuse limit 2
Color space: Gamma 2.2
This topic on the sidefx forum helped me a lot to achieve this render.
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=21548&highlight=&sid=70ad77079d133e173747271cc0618932
The most important light in my scene is the environment light that has an HDR environment map attached to it. I recommend taking out any walls or objects that may obstruct the light.
Peter Quint has a tutorial on this. Check out his videos and his scene files.
https://vimeo.com/42465610
System specs: Intel Core 2 duo, quad core q9950- 2.83 GHZ ; 8Gb of ram.
  • 2 weeks later...
