Daniel_123 Posted October 31, 2012 Share Posted October 31, 2012 (edited) I used Maya for modeling and Houdini for everything else. I exported just a beauty pass using Houdini`s Mantra renderer. For post processing I used After effects, but only for small color tweaks.The entire project took about 2 weeks and it mainly involved learning how to achieve a realistic look. The last 3 days were focused just on balancing the materials, lights and textures to achieve the final feel.Feedback and questions are appreciated. Edited November 29, 2014 by Daniel_123 Quote Link to comment Share on other sites More sharing options...
gui Posted November 7, 2012 Share Posted November 7, 2012 beautiful! How long was the render time and what was the specs of the mantra & system? Quote Link to comment Share on other sites More sharing options...
Netvudu Posted November 7, 2012 Share Posted November 7, 2012 I like the rug Quote Link to comment Share on other sites More sharing options...
Daniel_123 Posted November 7, 2012 Author Share Posted November 7, 2012 beautiful! How long was the render time and what was the specs of the mantra & system? Hey, thanks. The final render took around 9 hours, but I think I bumped up the pixel samples probably a bit too much for the PBR. Pixel samples 20 x 20, image resolution 1600px x 1080px. Other info: Diffuse limit 2 Color space: Gamma 2.2 This topic on the sidefx forum helped me a lot to achieve this render. http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=21548&highlight=&sid=70ad77079d133e173747271cc0618932 The most important light in my scene is the environment light that has an HDR environment map attached to it. I recommend taking out any walls or objects that may obstruct the light. Peter Quint has a tutorial on this. Check out his videos and his scene files. https://vimeo.com/42465610 System specs: Intel Core 2 duo, quad core q9950- 2.83 GHZ ; 8Gb of ram. Quote Link to comment Share on other sites More sharing options...
Daniel_123 Posted November 7, 2012 Author Share Posted November 7, 2012 I like the rug Thank you, Love the rug too, feels so cozy. Quite easy to create, just a fur sop attached to a plane. Modified a bit the plane to give it a “messed up” look. Quote Link to comment Share on other sites More sharing options...
neonbulbs80 Posted November 19, 2012 Share Posted November 19, 2012 What a lovely renders. I've been doing my own interior renders as well. Did you render them in passes or just beauty renders? Quote Link to comment Share on other sites More sharing options...
gui Posted November 23, 2012 Share Posted November 23, 2012 Thanks for the info!!! 1 Quote Link to comment Share on other sites More sharing options...
Daniel_123 Posted November 24, 2012 Author Share Posted November 24, 2012 What a lovely renders. I've been doing my own interior renders as well. Did you render them in passes or just beauty renders? Just a beauty pass and a bit of post-process. But would definitely recommend passes,... so much more control and a proper work process. It rhymes Quote Link to comment Share on other sites More sharing options...
Edreamer Posted November 27, 2012 Share Posted November 27, 2012 Cool!! 1 Quote Link to comment Share on other sites More sharing options...
