Rikrok Posted November 7, 2012 Share Posted November 7, 2012 I'm trying to get scrolling text across various primitives. That in itself was ok, using the shader to reference the cop node op:/obj/geo1/cop2net1/font1 My problem is getting the text to say different things based on a primitive's attribute. In the font node I'm reading a text file, and I want to be able to control which line it reads. I have a primitive attribute ($LINE), but putting that in doesn't work. I also tried.. prim("../../randomnode",$PR,"line",0) which crashes Houdini (works if I replace $PR with a specific primitive number, but of course that's useless). So eventually I gave up and created multiple font nodes each manually set to read a different line (far from ideal as they'll need to be hundreds) with the idea that in the material I can read the line attribute and append that number to op:/obj/geo1/cop2net1/font Doing that within the material VEX builder doesn't work (mantra: Unable to load texture 'op:/obj/geo1/cop2net1/font1') Promoting the texture and putting this in doesn't work either op:/obj/geo1/cop2net1/font`prim("../../randomnode",$PR,"line",0)` Please help! Quote Link to comment Share on other sites More sharing options...
Sifis Posted November 8, 2012 Share Posted November 8, 2012 I had a similar problem the other day, I wanted to vary COP parameters with stamping from a copy SOP. I ended up using it to drive VOP attributes inside the shader directly instead. I 'd like to hear from someone who actually made SOP generated attributes work in COPS. There's also this thread that could help you: ression-from-cop-to-sop/page__hl__+cops%20+stamp#entry95909 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted November 8, 2012 Share Posted November 8, 2012 I had a similar problem the other day, I wanted to vary COP parameters with stamping from a copy SOP. I ended up using it to drive VOP attributes inside the shader directly instead. I 'd like to hear from someone who actually made SOP generated attributes work in COPS. There's also this thread that could help you: http://forums.odforc...15510-stamp-expression-from-cop-to-sop/page__hl__+cops%20+stamp#entry95909 I had the exact problem before with stamping in COPs too. Quote Link to comment Share on other sites More sharing options...
Rikrok Posted November 8, 2012 Author Share Posted November 8, 2012 Damn. So I've resigned myself to having the COPs write out loads of images, the problem is this will need to be done frequently with lots of nodes. To save clicking render 100 times every time the text needs to change I had the idea to merge all the font nodes and then write to exr using layers to store the planes. It works in that I can see all the different text in their own layers in Nuke, but is it possible to access exr layers in a shader? Quote Link to comment Share on other sites More sharing options...
