symek Posted December 9, 2012 Share Posted December 9, 2012 Ray traced or depth map shadows? Do you have "Depth Map Motion Blur" on Light object (shadow tab) turned on? Quote Link to comment Share on other sites More sharing options...
dennis.albus Posted December 9, 2012 Author Share Posted December 9, 2012 (edited) We are using depth map shadows and "Depth Map Motion Blur" is turned on. However it does not really make a difference in this case if I turn it off. Somehow it seems as if the opacity of the samples is not correctly considered and thus the brightness is adding up. I attached a REALLY messed up testcase. You should render frame 7 and 8 to see the effect. mb_problem.zipFetching info... Edited December 10, 2012 by dennis.weil Quote Link to comment Share on other sites More sharing options...
dennis.albus Posted December 10, 2012 Author Share Posted December 10, 2012 I think I solved it. It was a combination of motion blurred shadow maps, velocity motion blur and deformation motion blur that somehow seemed to render at different subframes and got out of sync. Disabling shadowmap motion blur helped which makes sense as MP only shades one time (at shutter opening i think) and then drags the shading. Quote Link to comment Share on other sites More sharing options...
symek Posted December 10, 2012 Share Posted December 10, 2012 (edited) Yes, this is what I came to also, that's was something wrong with deformation blur and depth maps (seems like turning on ray trace shading on a object helps), except to me it looks like frame 7 is darken by double shadow, not 8 lighten by lack of it edit: it reminds me to say, how awesome is to have deformation blur working with fur. So much nicer motion blur! Edited December 10, 2012 by SYmek Quote Link to comment Share on other sites More sharing options...
dennis.albus Posted December 10, 2012 Author Share Posted December 10, 2012 (edited) Yes, you are right. Frame 7 got darker and not the other way around Deformation motion blur on fur is definitely very nice and it feels that it's not much slower than velocity blur or no blur at all. Another benefit is that it matches the blur on our characters perfectly. Edited December 10, 2012 by dennis.weil Quote Link to comment Share on other sites More sharing options...
dennis.albus Posted December 13, 2012 Author Share Posted December 13, 2012 Ok, guys, we are on track for a release tomorrow (fingers crossed). Meanwhile we leaked a single finished shot which you can see here: http://santa-und-klaus.tumblr.com/post/37808411803/die-anderen-sind-schon-daheim-ruhen-sich-aus-fuer Quote Link to comment Share on other sites More sharing options...
dennis.albus Posted December 17, 2012 Author Share Posted December 17, 2012 We are finally finished I opened another thread in the final art section as I think this is more appropriate from now on. Just use this link: Best, Dennis Quote Link to comment Share on other sites More sharing options...
