lukeiamyourfather Posted November 20, 2012 Share Posted November 20, 2012 The new feature in Houdini 12 for simulating Pyro clusters is pretty cool and very efficient for the simulation. I'm trying to get the simulation caches back into Houdini (to view and render the results) but I don't see a straight forward way of doing so. I used the "${CLUSTER}" variable in the name for the export ROP that went to HQueue but that only works for the export, not for reading the simulation back in. Am I missing a straight forward way of reading the simulated Pyro clusters back in or is it a one way street to use the "${CLUSTER}" variable and you just make a bunch of file nodes to get them back in? Quote Link to comment Share on other sites More sharing options...
Macha Posted November 20, 2012 Share Posted November 20, 2012 You can append a copy sop to the file node and then make a copy variable and reference that in the filename. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted November 20, 2012 Author Share Posted November 20, 2012 That's really simple and makes a lot of sense. Why didn't I think of that? Thank you! Quote Link to comment Share on other sites More sharing options...
